Question about Invacare Supply Group Invacare Lynx L3X 3 Wheel Travel Scooter Blue
Invacare three wheel scooter got wet wont run?
It was outside and it rained before I could get it under cover. Now it will not do any thing. Batteries are at full charge. No lights when I turn the key
Posted by Jerry Dute on
5 Related Answers
oregoon
  • 175 Answers
SOURCE: My wife has an Invacare Buzz scooter - I have got
The Buzz breaks down into four pieces for transport. Electrical connections must be unclipped to separate it completely. It is possible that one of the connections isn't completely clipped together, so my first check (after you have made sure that you have it plugged into a working outlet!), would be to take it apart and then reconnect everything firmly. While you are at it, you should look for any other clip-connections and undo, then redo all of them. Even those that "look okay". Inspect the connections metal fittings for signs of corrosion or dirt that may be causing a high-resistance connection, and clean as necessary. Run you fingers along the wiring to check for any places that my have been damaged, breaking a wire connetion in mid-stream. Make sure the connections to the batteries are clean and free of any corrosion too. Be sure to check the fuses to make sure you haven't blown one, and also push in your circuit breaker. These sometimes trip while charging due to spikes caused by thunderstorms. If you do all this and it still isn't charging, you'll need to open the shroud at the head of the tiller and inspect the connections running up inside the tiller, and the connections going to the PC board located at the very top of the shroud where the thmb-paddles hook into the electrical system. There should be a fuse inside there too, so check that.
Good luck.
Posted on Jul 11, 2009
Barry Nixon
  • 103 Answers
SOURCE: Have an invacare patriot LX4. Unit takes full
Check to see if the scooter is in freewheel mode. To know if the batteries are bad you need to charge them for 10 - 12 hours and then have them tested with a load tester.
Posted on Jul 29, 2009
Titilayo Sodipe
  • 1428 Answers
SOURCE: What is Invacare Supply Group?
Really i don't know the charge. Contact Fixya Team on [email protected]
Visit http://safemanuals.com/user-guide-instructions-owner-manual/LYNX/4TS630A-_E
Cheers
Posted on Mar 11, 2010
Anonymous
  • 26 Answers
SOURCE: I have a Invacare Battery charger and the green
charger broken can be repaired call
0208 676 0944
Posted on Apr 15, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: I have an invacare scooter that doesn't work. Can
mcdevito75 here, It could be the battery--ies need re-charge or replacement, online at Invacare.com they can help out, or almost any Medical Supply store in your area.
Posted on Jun 23, 2010
Where is the serial number found on a Invacare Aurgia10 4 wheel model Mobility Scooter.
Hi most scooter's have a sticker on the seat support shaft under the battery & motor cover cowling. Cheers
May 12, 2018 | Invacare Health & Beauty
Why is my Invacare leo mobility scooter stopping and starting
It could be the wig-wag at fault and need replacing. A loose or bad connection on batteries or drive system. Speed pot worn.
Are the batteries old? May need load testing.
Mar 07, 2015 | Invacare Leo 4 Wheel Mobility Scooter...
Wherecan I find information about an Invacare scooterFixing an Invacare scooter?
Hopefully you have kept the old set of batteries, I would get them tested plus have the charger tested also.
May 09, 2014 | Invacare Health & Beauty
I have a pronto m51 wheel chair got the joy stick wet it flashes 7 times how can i fixs it
Here's your M51 manual:
http://www.invacare.com/doc_files/1125085J.pdf
Trouble codes start at p25.
Also, Invacare is proud of the M51's wet-weather performance (check the "Rain Test" chapter in the manual. You might have a warranty issue. Check with an Invacare dealer.
May 06, 2014 | Jet 3 Ultra Power Chair
What do i do..mk6-mpj invacare joystick got wet and wont turn on
Hi, you can send it to me for testing , free , you only pay for the postage back...(UK only)
Regards
Rob
www.gewizrepairs.co.uk
Nov 22, 2013 | Invacare Mk6 Mpj Ts1136885 Joystick...
My rascal scooter was making a wining noise now it wont go
Hi, Firstly disconnect the batteries and let the scooter dry out,
1. Does the scooter now turn on ? once batteries have been reconnected.
2. The wining noise was coming from the rear ?, if so firstly check the wheels are okay can be turned around, now the noise was most likely coming from the motor or gearbox, can it turned round in free-wheel okay , this will prove that the gear is not jammed etc...
Please update me on the situation.
Regards
Dec 20, 2012 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Pride Pursuit XL scooter won't charge
Is this the Pride Colt XL 8 scooter ? if so look at the steering column, there is a fuse here for the charger ?
Please give feedback.
Dec 19, 2012 | Pride Mobility Pride Pursuit XL 4 Wheel...
No power when key is turned on
It sounds like the batteries have gone bad and need to be replaced. Check your fuses as well.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. When you turn on the power chair, nothing happens. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Your warranty will most likely not cover replacment as this is due to customer neglect, but your insurance may still cover the replacement if you can wait for the process to go through. Otherwise, you will need to replace the batteries on your own, type U1, 24v 33 amp. Good luck!
Dec 18, 2010 | Invacare Supply Group Invacare Lynx 3...
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Blinking charge light on Invacare Zoom 300 scooter
Can you try another charger ?
Is it a onboard charger ? if so they do go wrong, Are they supply MK batteries ?
Check the leads from the charger connection socket to the motor controller board.
Regards
GeWiz.
Oct 03, 2009 | Invacare Pronto M51 Power Wheelchair
Invacare Supply Group Invacare Lynx L3X 3 Wheel Travel Scooter  Blue Logo
91 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
