SOURCE: water keeps draining
You may be experiencing what is known as "siphoning". If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain. You need an air gap in order to prevent this. Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches. If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests. Makes sure there is still an air gap around the hose. That is, make sure the hose isn't seated so tight that it seals off the standpipe completely. This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening. Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe. In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor. If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here. There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem. You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise. This is air being reintroduced through the drain line. I hope you find this information helpful.
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
SOURCE: Have Stackable Kenmore Washer/Dryer Model
The squealing could cause from the belt that drives it
SOURCE: kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
SOURCE: Kenmore Stackable Washer cold water does not work
Hello there
There's no cold water
Some
washing machines allow cold water to enter only during certain cycles.
Others intermittently allow hot and cold to enter, to temper the
temperature of the water. Consult your owner's manual if you are unsure
about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
Is the cold water turned on? If not, turn it on.
Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
Is
there cold water coming through the proper hose? If not, check to see
if the screen inside the water-inlet valve is clean. (The water-inlet
valve is the device on the washing machine that the fill hoses are
attached to.) If it's clean, you probably have a defective water-inlet
valve. If so, you need to replace the valve.
It should look something like this picture below
Testimonial: "good"
