Question about Sony PlayStation Portable (PSP) Console
Psp Disc can not be read
Every game I put in says disc can not be read.It is spinning up and I can see the red light.I cleaned it but is still does not work.
Posted by mdorsey111 on
  • Anonymous Dec 27, 2007
    I too have a problem, I ran the cleaner in the unit. Madden Football runs, but when I take it out and run Tiger Woods golf game it goes on and on with clicks and the blue screen but the game does not start. Went back to Football game and it started. This happens on Baseball, Hockey and other games........
    HELP,HELP,HELP..........
Greg Stokes
  • 709 Answers
Hi Mdorsey,
You probaly have something jamming the Laser fro moving. Sometimes you can clear this by forcing the laser to move some. You will hear it click a few times. Once you click it a few time on way or another. Try a UMD to see if that fixed it.
Posted on Nov 06, 2007
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
Tip
Psp ps2 ps3 xbox360 netindo repain in mubai and in navi mubai and in andheri and...
9867244969 Psp repair in Mumbai , ps3 repair in Mumbai , xbox360 repair in Mumbai , ps2 repair im Mumbai psp repair ps2 ps3 repair xbox360 repair 9867244969 psp modchip Hello all We are specialist of all kinds video game. We have 10 year experience. We stables 1999 year We are sales and repair shop. We are can repair all kinds of problem Ps2 : modchip, lanes, no power, no video, mother board change any IC, no disc reading Ps3 : power light only red, no video, no disc reading, disc error, on after become red light, ps3 red light, PSP1000, psp2000, psp3000 : all software and hardware, psp hack, psp games, psp firmware psp custom firmware, chicken, LCD, display, psp adapter Xbox360 : 3red light, 2red light, open tray, disc error, latest game not working, xbox360 hack, xbox360 spftmod , xbox360 adapter Wii : power problem, disc error, 003 error, wii softmod, wii hack wii lanes, wii adapter NDS lite : power problem, LCD problem , no cartridge, no SD card sony service center contact person seraj 9867244969
on Sep 19, 2010 | Video Game Consoles & Games
Psp will not read discs
try clean the disc or putting the disc in a new cover
Jul 22, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
PSP Not Loading Games
You most likely need to clean the lens. Local game stores have kits that clean it for you.
May 28, 2009 | Sony PlayStation Portable (PSP) Console
Psp spot repair in mumbai :- 9819767710/9867635653 ?
what was that????don't u have any better prob. to ask.....
Jan 23, 2009 | Microsoft Xbox 360 Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Help!
You might have PSP stop reading UMD discs, First you will do some trouble shooting with what might be wrong with your PSP unit.
first is the Disc Spinning motor. This will not let The disc in the UMD spin. On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
2nd is something stuck in the UMD gear, try to clean the gear of arm of dust, plastic, soda, and even hair.
and at the last is the actual laser itself. It will not focus the laser to read the UMD disc.
Hopefully this help, Pls post back should you need additional information...!
Jun 01, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
127 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Lee Hodgson
Lee Hodgson
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
