Question about Boating
Mercury optimax problems
Hi can you please help, my 75 optimax outboard motor beeps 4 times and goes into idle mode we have changed the alternator, checked oils and topped them up, water pump works good.
Posted by Beckie on
ray gallant
    Top Expert:
  • Boating Master
  • 68,537 Answers
I would reccomend contacting the dealer .
Posted on Nov 03, 2014
5 Related Answers
Fame_Guru
Sid
  • 483 Answers
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
Posted on Mar 20, 2009
Anonymous
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at [email protected].
Posted on Jun 16, 2009
Anonymous
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
Anonymous
  • 207 Answers
SOURCE: johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Posted on Jul 13, 2009
Anonymous
  • 86 Answers
SOURCE: My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Posted on Aug 06, 2009
Mercury 150hp Optimax outboard
clean the connection on the back of the tachometer and on the sensor in the engine. If the engine remains at 2,000 rpm and won't go faster, you need a marine engineer with diagnostic equipment. That is a big engine on an 18 foot boat!
flooded cowl
Mercury Optimax loss of rpm
Injector, Coil, spark plug diagnostic
How to Diagnose Injector or Coil Fault on Mercury Optimax 150 HP Outboard...
mercury 150hp optimax outboard tachometer Google Search
Sep 01, 2018 | Boating
2000 mercury 75 horse wont idle or run trimmed down but runs and idles trimmed up
Good Day
The Carburettors Need Servicing And float Levels Adjusted correctly
Apr 02, 2017 | Mercury Mark 75 Outboard Boat Motor...
Why does my mercury outboard idle perfectly but stall out under load?
Your carbs are probably dirty. Remove the carbs and clean out all jets and passages with carbcleaner and compressed air.
Nov 13, 2014 | Clymer Mercury/Mariner 75-275 Hp...
Tilt/trim on mercury optimax 225hp outboard motor goes down ok but barely moves up
first thing to chceck would be the oil level..if thats ok then I might want to know if the oil looks milky. if it is then you have water in it.needing drained and replaced.
Oct 06, 2014 | Boating
75 2 stroke mercury optimax motor problems
4 beeps every 2 minutes has 2 causes:
1) LOW oil level in the engine mounted reserve tank ( fill it up manually )
2) Water in the engine mounted water separator/fuel filter ( clean out )
Jun 10, 2014 | Boating
Why won't my mercury optimax 150 outboard start?
your owners manual should tell you what the beep code means.or call a dealer and ask them.
Jun 08, 2014 | Boating
Why won't my Mercury Optimax 150 outboard start up. Engine turns over just fine, and there's 2 beeps to the throttle box.
I usually do cars and trucks, but if you are getting an electronic beep, you might go online and refer to an engine Manual for what you own. You may have a low oil lockout for the crankcase on a 4 cycle or a low oil cutoff alert for a 2 cycle with an automatic oil feed mixer. Some transition of inboard-outboard technology to outboards can include tilt lockout so that you can not start up in gear. Most prevent the starter from turning, but could keep the engine from firing if they want to wire it that way. With the "beeps" it would seem to be a Code.
Jun 08, 2014 | Light Outboard Motor Boat Bass Fishing...
Temperature of 2008 75hp Mercury optimax
You may be able to find the best answer on the Mercury Outboard Forum.
May 28, 2013 | Boating
Boating Logo
582 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
