1800cc. This car has nothing at take off, to the point where it could cause an accident its so slow. engine runs well. When driving up a hill around 70km at about 3100rpm the car lurches like the trans in slipping or cant decide where it should be set on the internal pulleys. But when you put the throttle to the floor, the engine will scream but the car does not take of like it should, as you let the revs off the car lurches forward like a manuel car with a worn out clutch grabbing again. Any advice would be most appreciated.
SOURCE: clutch slipping on 2004 350z roadster
This is a Hydrolic System ,thus there is no Adjustment for what you discribe, You will need a New Clutch Assemble. I Recomend replacing ALL Clutch Parts while Trans is out. Uncluding All the Parts Listed Reliece Bearing, Clutch Disc, Pressure plate,And Renew Slave Cylinder FLUID.
SOURCE: 2002 nissan altima in drive position was driving very slow
THrottle position sensor check that.
SOURCE: High idle speed- Nissan N16 Pulsar/ Almera
Battery not charging well when airconditioner on ( also engine speed not increase when air conditioner on )
SOURCE: Transmission slipping
My maxima uses only Matic K fluid. & I think another dealer put the wrong one druing service but no way to prove it. But it's 100% your transmission. I've been complaing since i got my maxima in 05 brand new. within 5000 miles I was complaing its transmission. Now today I have 52000miles now they admit something is wrong Luckly i was under warranty. I've been informed by former mechanics if once dealer does not find anything the 1st time they call all the local dealers & give eachother a heads up no to waste time on that specific car.I had to push the service advisor to go for a test drive to prove my car was having problem.
Good luck man
