Question about Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Does Not Autofocus
My nikon D50 is just over a year. It worked fine since its purchase and i've taken great care of it. Since couple of days I am seeing a problem with it. While using manual focus it works fine. However if i turn the AF on then it does not autofocus at all. Sometimes the config screen shows r09 when i press shutter halfway.
I have tried using 3 different lenses and one of them is brand new delivered just today (Nikon 50mm).
It the camera's built-in focus motar is dead?
Posted by photoicon on
  • freshfire8 Dec 17, 2007
    My Nikon is doing the same thing. I have had it for approximately a year and a half and it will autofocus fine with the lens that came with it but it won't focus with any other lenses now. It has been working fine with my macro lens until about 2 wks ago.
Anonymous
    Master:
  • 619 Answers
Replace the lithium battery 1.5X2 . then press then ok good, but does not work the drive motor was broken.
Posted on Dec 29, 2007
Dropped my Nikon D50 and now it shows there is no SD card in it and the battery indicator is flashing. Nothing appears on the LCD - including the menu. I've taken the SD card out and the battery and...
Contact Nikon tech support at www.nikon.com to see what they recommend. I don't think the warranty covers abuse such as dropping the camera so you may be in for an expensive repair. However, he Nikon techs may be able to suggest something that might help you avoid that expense.
1helpful
Nikon auto focus not working and all other settings come out blurry. Not sure how to get it to work. It makes a noise as if trying to focus and never shoots.
Okay well without repair the unit will not be fixed. the issue is autofocus sensor inside may have failed or is out of range. This can be taken care of at a camera shop. This cannot be fixed by a end user and over a email solution. A repair shop would be the recommended course of action.
Thanks and I hope this doesn ot effect how you rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
1helpful
Nikin D50 autofocus
I figured out that when changing lenses my finger must have hit the little switch and flipped it over to manual focus. I changed it back and it now works. Thanks.
Shutter is not workin properly
Just clean propely with genuine cotton cloth ,it may work fine .
2answers
Nikon D50 Autofocus
MaiaM,
I am having a similar problem with my D50's shutter. My problem seems to be related to the position of the camera. If I rotate the camera vertically to the left - it functions fine. Rotated to the right - it acts as is as if the shutter button is not working at all. Horizontally positioned - the shutter works about 85%of the time. Is your problem positionally influenced as well?
2answers
Nikon D80 Autofocus problem
sir, replace ur lens image reading sensor
2answers
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Nikon D50 Digital Camera with 18-55mm Lens Logo
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
