Question about Jenn-Air JCD2295HES Side by Side Refrigerator
Jenn air not making ice - Jenn-Air JCD2295HES Side by Side Refrigerator
5 Related Answers
TampaNative
Frank Fernandez
  • 778 Answers
SOURCE: Ice and water hook up for Jenn-air JSD2789GEB
The water coupling is usually located at the bottom rear of the Fridge and will require an installation kit (easily obtained at your local Home Improvement Store) and tapping into an existing copper cold water pipe (the kit will/should includes the line tap).
Posted on Apr 26, 2008
worldvet
Glenn Rogers
  • 859 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
Towards the bottom of the freezer is the water diversion tray for when it defrosts. It is usually made of glass but may not be. Lift that up an see if it is blocked by frozen water ice blocking the cold air vent that recirculates and also feeds into your refrigerator.
If this doesn't help wait long enough and one of the other experts on the site will help you. If it does solve your problem I wouldn't be too surprised as I've seen this so many times.
Well, regards and good luck,
Worldvet
Posted on Jun 02, 2008
docjohn174
john gagnon
  • 943 Answers
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
John Morganti
  • 864 Answers
SOURCE: Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice.  Check it tomorrow.
Posted on May 31, 2009
Anonymous
  • 39 Answers
SOURCE: 4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please [email protected]
Posted on Sep 09, 2009
The ice maker in my Jenn Air refrigerator stopped working.
Check that there wasn't a clog in the line after replacing the filter. Make sure you get water going to the solenoid, if so, it may either be a clog in the solenoid or a fluke that it's no longer working.
Sep 10, 2009 | Jenn-Air JCD2389G Side by Side...
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
May 31, 2009 | Jenn-Air JCD2295HES Side by Side...
My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
[email protected]
Mar 25, 2009 | Jenn-Air JCD2389G Side by Side...
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-Air JCD2295HES Side by Side Refrigerator Logo
55 people viewed this question
Top Jenn-Air Refrigerators Experts
john h
Sheldon Dedek
Marvin
Marvin
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
