Why is there almost no output from the HK3550 Receiver, when supplied with signal input the out put side (speakers or headphones) has just a faint, faint sound output (speakers or headphones) through the left and rignt channels. No obvious signs of distress inside the machine like smoky spots or craters on circuit boards.
SOURCE: Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
SOURCE: HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
SOURCE: I have a problem that
Hmm, crunch is bad. There is the slighest chance that a common control may have developed a high-resistance or 'dead' spot and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control. If it still doesn't work you might want to prove if its a low-level signal issue or a high level amp failure. One way would be to run an RCA cable pair from the Tape Out to any other device (even a TV) you might have that accepts an audio input. If the 'crunch
SOURCE: Harman Kardon AVR 340 Receiver Has no sound. It
What is the state of the indicated but inidentified digital source? It's trying to tell you to check IT.
SOURCE: I have a hk 3380
It looks more likely to have a problem with one of the relays or a 'cold' connection inside the unit.
Kostiko
