SOURCE: What does error code 02 F mean
youll need to remove the lower accces panel, (3 screws across the bottom of unit) behind htere will be a teurn screw giving access t o the pump cleanout, possible that it is full with gunk/debris, preventing proper drainage. F 02 poor drain
If ! light displays a solid light it means that the printer front door is open, print cartridge is missing, or a flash option has been installed that is not supported. Please Close the door, install a print cartridge, or install a supported flash option. The printer will automatically reset.
If ! light and Continue button (green button) displays a solid light, it means a printer error. The printer memory is too full to collate the print job. To continue printing press and release continue button to clear the message. To cancel press and release the X (red button).
You may also press Continue button twice quickly to see the secondary error code. For further assistance, please call Lexmark Technical Support.
