Question about Kenmore Ovens
Oven is 8 years old. Will stay on at times , but at other times it will cut off after about about 1/2 hour
Check the main board for a bad solder joint at one of the relays. Repair or replace as needed.
Posted on Feb 02, 2015
SOURCE: Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Posted on Oct 25, 2006
SOURCE: B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Posted on Mar 26, 2007
SOURCE: Oven cuts out after ten minutes and comes back after cooling down.
The control switch on our AEG B3000, a similar oven, had burned contacts which prevented the fan from running in one selector position where the fan was to run when the heating element cycled off. The tech replaced thermostat which was not problem at all. If the fan does not run in this mode the heat stays at the top of the oven near the thermostat and prevents proper heat build up. Switching to 100% convection fan mode solved problem until switch replaced and all switch positions worked again. Hope technician will now refund for thermostat which was perfectly fine. Always check thermostat in boiling water before replacing.
Posted on Feb 17, 2008
SOURCE: Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
Posted on Jul 06, 2008
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Posted on Feb 04, 2009
