Question about Samsung HL-R6167W 61" HDTV
I replaced the lamp on my samsung HL-R6167W and the tv will turn on to a black screen then shut off what could be wrong?
Posted by austin Lisonbee on
  • Vista Electronics Jun 16, 2014
    Hi austin Lisonbee, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    What was the original symptom ? What lamp part number did you install ? When it shuts off what lights are blinking on cabinet front and what sequence or series ( blink code ) ?
5 Related Answers
SOURCE: t.v. will not turn on. flahes "lamp" then no picture!
I have a picture but the tv will periodically turn itself off during the day and then flash the 3 blinking lights...anyone know what the problem could be. We can fix it ourselves if we knew for sure what it is.
Posted on Jun 06, 2008
Anonymous
  • 2920 Answers
SOURCE: samsung HL-R4667W black screen, display says "Lamp"
it means you need to replace a lamp when it says that
Posted on Jan 30, 2009
saidneurot
Ness
  • 128 Answers
SOURCE: The TV made a pop noise and the TV shut down. I
here is this could wrokhttp://www.ehow.com/how_5535314_reset-lamp-hours-tv.html
Posted on Jan 15, 2010
salt56
TV Doctor
  • 373 Answers
SOURCE: When I turn my tv on it just hums and it sounds
You have a bad color wheel that is broken. To get the right one you must have the model number and the version code. The version code is on one side of the TV at the back. Will be two letters and two numbers. Installing one can be a bit of a pain if you have never taken one out and replaced. You have to pull back the light engine to see the color wheel. The light engine is the main box like module that has the projector lense. A screw(s) holds in the color wheel and has a wire plug to it as well. Do a search on Google or Ebay etc. to find the part to purchase. Again the version code is very important! Before buying I advise that you take the color wheel out to inspect it for damage. When installing the new color wheel DO NOT touch the wheel itself.
Posted on May 24, 2011
Anonymous
SOURCE: Hello I have the samsung
vertical lines and all over the place
Posted on Sep 25, 2011
1helpful
Samsung DLP HL-R6167W 61"
try removing the lamp again ,inspect it for hair and blow some air into the lamp housing,if this is new to you after replacing the lamp,its possible its been created .
2answers
T.v. will not turn on. flahes "lamp" then no picture!
This will have to be narrowed down to a specific problem. I would try the easiest things first. First check the lamp. Is it bad or just starting to go bad or does it just need to be reseated with the ballast? If the ballast flickers when turning on your TV, then you will know it is the lamp that is not working or the ballast may need to be replaced. If that is not the problem next check to see if the color wheel is spinning or broken. If broken, it will need to be replaced. If not spinning it is the DMD board that is bad. The color wheel is plugged into the DMD board. If the DMD board is good it will spin the color wheel, that is what will start your lamp. When you lamp starts, you have your picture.
My tv turns off
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Samsung HL-R6167W 61" HDTV Logo
Ekse
Demonic-2011
Demonic-2011
