Hello. The closest model to the one you say you have is
79092702011...
There is nothing on the sears website remotely close...The elements, if this is the real model you have, are as follows:
bake...316505500
Broil...316203301
I hope this helps you...
It sounds like the keypad is not compatible with the main garage door. Make sure the keypad is the correct only for that model number opener. Older models will not work with newer openers and vice versa.
It is possible you need to replace your heater element or your thermostats .. depending on your model which you did not list. Your element and thermostats will cause it not to heat ... when you get your model go to www.sears.com/parts and you can possibly view your schematic if sears had ever sold it... get an ohm meter there cheap Lowe's home depot sears test for power on each of the three. clean the venting also..
I think you are holding the smart/learn button too long. Press and hold the button on a remote and then press and immediately release the smart/learn button. Do this for each remote.
i used to be sears repairman ask him if there is a recall on your pacfic model .. betcha there is on the dryer drum tell him u want the whole drum replaced on dryer u know exsisting problem having on this pacfic dryer remember satisfaction gaurented or money back...
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
You can find exploded views and order parts by entering your model number at the Sears parts site.
There
may also be a "mini-manual" (tech sheet) hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
