The E327 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible and will not work in devices not designed to accept SDHC cards. You need to use SD cards, 2GB and smaller.
The DX6490 works with MMC and SD cards. While an SDHC card will fit into the slot, it is electronically incompatible and will not work. Some Kodak cameras can use SDHC cards, but the DX6490 is not one of them. You need to go with SD cards, 2GB and smaller.
There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
The V530 works with SD cards. Your new 8GB card is an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards, 2GB and smaller.
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
sorry but the sdhc card wont work for that model... that type of mem card only works for compact cameras ( think higher/latest cam models).. so dont buy it, you will only get errors when u use it for ur camera and even if u format it over and over put it in put it out in out, still wont work
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
