Question about Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV
Why will pioneer elite pro-930hd display not power up
The media center stand-by led flashes red. When I disconnect that from the display and plug the display into an outlet, only a loud noise is emitted from the back of the display and the display LED does not glow red or blue. The screen remains black.
5 Related Answers
Anonymous
SOURCE: pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Posted on Jan 01, 2008
spamalot
SOURCE: plasma problems
HI
THANKS FOR YOUR QUICK REPLY. I NOTICE YOU ARE BASED IN THE USA, I AM IN THE UK (JUST ACROSS THE POND) ARE YOU ABLE TO ASSIST ON THE UNITS THAT ARE SOLD HERE. IF YOU CAN THEN IT MAY WELL BE WORTH SUBSCRIBING BEST WISHES DAVE FOX.
Posted on Mar 07, 2008
Anonymous
  • 197 Answers
SOURCE: will not power up fully
power supply call pioneer
Posted on Jun 07, 2009
Anonymous
SOURCE: Red LED lights
power supply shot ... sometimes x board or y board
Posted on Dec 09, 2009
rickbrashear
Ricky brashear
  • 176 Answers
SOURCE: Power Surge
charlie the proble has something to do with the tv guide here is a response from an older post Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was. Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Posted on Aug 06, 2012
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
Pioneer plasma pro 930hd tv no power
if the power board looks good my guess it is the main ic that is broken
Nov 22, 2017 | Pioneer PRO-930HD 43 in. Plasma Television
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
PIONEER PDP-R06U / PRO-R06U MEDIA RECEIVER SERVICE
Hey,
This may be too late...
I got it from the field manual.
Trap Switch Reset Procedure
G-4, G-5, G-6, G-7, G-8
• Replace media receiver, plasma panel cover, or tape down HDCP trap switch.
If the model in question has the TV Guide option, the TV Guide
option must be turned off before proceeding.
• Using the customer’s remote control enter “service mode” by pressing the
following key sequence:
1. Press the “display” button then release the “display” button.
2. Wait between 3 and 7 seconds
3. Press and release the “<”, “^”, “<”, “>”, and “power” buttons in sequence.
• Panel will now turn on in “service mode”.
4. Press “muting” button 3, 4 or 5 times depending on model you are working on.
Until the display shows the “initialize” page.
5. Press and hold the “display” button until the error indicator (red LED) on
either the panel or the media receiver goes out.
6. Exit service mode by pressing the “power” button on the remote.
I had to try it a couple of times before I got it to work. I.m not too sure how to turn off the tv guide mode. I just held it in for a couple of sec,s.
Good luck
Dec 05, 2009 | Pioneer Audio Players & Recorders
Pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer elite pr-1010hd plasma tv
It has an internal problem. Needs a local repair man. :(
Jul 13, 2007 | Pioneer Elite EX500 600Watt A/V Receiver...
Pioneer PureVision PDP-4340HD 43 in. Plasma HDTV Logo
Top Pioneer Televison & Video Experts
Demonic-2011
Demonic-2011
Raj Patel
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
