Question about Epson Stylus Photo R320 InkJet Printer
The flat white cable inside the nx125 printer has curled up?
Print job barely visible
Have you tried configuring the settings? I had that problem with an Epson Stylus NX125. I put in all new cartridges, went to properties and tried all options. setting it to black & white, then to color and the greytone. Printing samples after each change. I finally came up with an acceptable print after moving it back to color.
Mar 14, 2013 | HP Officejet Pro 8500 All-in-one -...
Epson nx125 black faint patchy
Most likely this could be because of Faulty Printhead/Cartridges in your printer.
If you have replaced Black and still find printing Quality issue, the Printheads need to be cleaned.
My suggestion is to click on the link below and the website is helpful in dealing with all type of Epson printer issues.
Click here -> Printer Issue Troubleshooting
Regards,
Suhail
May 20, 2012 | Epson NX125 AllInOne InkJet Printer
How to reset the NX125 ink levels?
You can not reset it. The place where you got the remued cart from has to do it. But, many times it does not matter - some older printers will print anyway, just the level indicators will not work. Some newer printers will not work - bad design idea to have a printer not work just because the "blue is empty". I still would like to print black! Brother printers are notorious for this - I won't buy one again. Anyway, most remued carts I buy come with instructions to ignore low ink level warnings.
Mar 27, 2012 | Epson NX125 AllInOne InkJet Printer
Lost Disc Foe Epson TX121/Nx125 Epson Me 320
Hi Mala Borwnlee,
Good day! You can still download the drivers/software for your Epson TX121/Nx125 printer by clicking on this link. Once you're there, just select your operating system. Then, all you have to do is to hit on Download Now. Finally, you can go ahead and install it on your PC.
Hope this helps.
Thank you for using FixYa.
Nov 24, 2011 | Office Equipment & Supplies
I bought a Epson Stylus NX125 and I don't know how to set the printer to print only Black & White.
You can control the format of your print-out via your Windows Printer properties (e.g. in W7: Control Panel -> Hardware and Sound -> Devices and Printers -> Printers and Faxes section -> Double click on Printer -> Pinting preferences) : under Preference/Features - 'Color Options' should set to 'Print in Grayscale'.
Sep 22, 2011 | Office Equipment & Supplies
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My windows xp can't find my epson stylus nx125 printer driver
You can get them from EPSON website and install them:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=150186&prodoid=63088088&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=20&y=10
Just choose what youi want, a complete (40MB), or Driver only (8MB)
Drivers and Utilities Combo Package
Windows 7 32-bit Edition, Windows Vista 32-bit Edition, Windows XP
epson13804.exe - 40.9MB - posted on 09/15/10
This file contains everything you need to use your Epson Stylus NX125 and NX127 with Windows XP, Vista 32-bit and 7 32-bit.
This combo package consists of the following items:
  • Printer Driver v6.72
  • Scanner Driver v3.770
  • Epson Status Monitor 3
  • Event Manager 2.40
Driver only:
epson13802.exe - 7.9MB - posted on 09/15/10
This file contains the Epson Stylus NX125 and NX127 Printer Driver v6.72. The Epson Status Monitor 3 is incorporated into this driver.
Please leave rating if it helps.
Jan 20, 2011 | Office Equipment & Supplies
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Red paper light is on even though there is paper in the tray. brother 2040 model.
This is a paper jam. Remove paper try as well as the toner/drum unit. Take vacuum and clean out inside the printer. Separate the toner & drum units and vacuum-blow out the drum unit to get it clean. Run the drum wire cleaner tab (purple/blue tab at front of the drum unit) back & forth a number of times. Sounds like you've got a piece of paper stuck inside somewhere. In the back of the printer, there is a door that will open out and down...check here for a speck of paper that is causing the paper light to come on...it "sees" something is in the way) since this is where the paper curls up and out the top. Reassemble toner/drum unit. Before you put the paper tray back in, take a piece of paper and feed from the front (use light card stock or heavy weight paper since this will help push out anything inside that's in the way) and print a few pages this way. Then, make sure your paper is dry (hasn't been in humid area) and is lying flat (not curled at edges). That should do it
Dec 21, 2009 | Brother HL-2040 Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Epson Stylus Photo R320 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Falling star
Kyocera HP Expert
Kyocera HP Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
