Question about Laser Canon imageCLASS 8180C Multifunction Printer
Install new thermister but error is e000-001 Solutions for e000 Issue
Need Thermister replacement connector
Cut the wires and wire nut them together. That will work.
Mar 24, 2017 | LG 6322FR2046C Thermistor
Tengo una image class mf 6540 marca error E000 NOSE COMO QUITARLO
Hi
This error is caused due to faulty thermister however; you can check the fuser unit for any jammed paper around the upper fixing roller and try to clean that area. After this is done try to clear the error by entering the service mode, to enter press Additional functions, #. Then go to #7 Printer and press OK, then go to #4 printer reset and press OK, yes= *. If the issue returns then replace the thermister. Hope this helps...please post back for further assistance.
Daniel
Sep 28, 2011 | Canon ImageClass MF6540 Copier
I have a Canon ADY0002 plotter with an E146-4001 error. Can you help?
Hi
Daniel
Jul 28, 2011 | Office Equipment & Supplies
LG wm2487hrm Washer not draining water. tE flashing. I drained water out of front and ran 2nd cycle same issue.
tE is a thermister error. It is a temperature sensor at the bottom front of the washer. tE can also be caused by a heater error. Some models have a seperate thermister, some incorporate it with the heater. It is very difficult to replace without taking the front off the machine.
Jan 25, 2011 | LG WM2487H Front Load Washer
Canon NP 2120 Copier that is giving Error Code E004 on power up. Any solutions?
E004 CODE IS FOR FIXING UNIT TEMPERATURE IS NOT REACHED THE SPECIFIED RANGE. CHECK HEATER LAMP, THERMISTER, THERMOSTAT.
Dec 18, 2009 | Office Equipment & Supplies
Canon gp 215 error e000 how do i solve the problem
This error points to the main thermister in the fixing unit not reaching high enough temperature. You'll probably need a new fixing film as the thermister for this machine is located within this unit (fixing film). Try restarting the machine, it may go away temporarily but will certainly return.
Jun 30, 2009 | Canon Office Equipment & Supplies
Error message
I have the same problem. It is caused by the thermister thermal probe going bad (open circuit). Delonghi wont sell you the probe which probably costa about $2, they want to sell you a new control panel for $93. You can replace it with another thermister and it works but it will probably be out of calibration.
Jul 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Konica 7020 Printer
HI,
you need to reset the fuser latch as it has a fuser error code most likely needs new thermisters,
anyways give this a go, hold down 2 and 5 keys together and power on machine, this will put you into to a service mode call 25 mode, go to dip switch 3 and bit 1 and then next to bit 1 hit the key that says turn off,
turn machine off and back on should clear error code, if it doesnt you need new thermisters, even when you put in new thermisters you still need to clear this error in service mode
Regards
Konica Tech
Feb 15, 2008 | Office Equipment & Supplies
I have a Canon Image Runner 1670F
That is a fuser problem,lamp,or thermister.
Jan 10, 2008 | Canon ImageRUNNER 1670F Copier
Laser Canon imageCLASS 8180C Multifunction Printer Logo
22 people viewed this question
Top Laser Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Barbat Nae
Barbat Nae
Scott Kalvinek
Are you a Laser Office Equipment and Supply Expert? Answer questions, earn points and help others
