Question about Dorel Alexander
Oke futon hey do you have any instructions on how to assemble one
2 Related Answers
Anonymous
  • 3 Answers
SOURCE: missing assembly instructions for Dorel futon
I had the same issue. Do a google search for Dorel Futons. WHen you see a variety of futons displayed, click on the one with the black metal frame (assume that is the type you have, as mine is F 14000BLKS). The one I chose was Vermont Styloe Metal Arm Futon 3123098W, same type of frame I have. Under the Description, you will see a link for instrucitons. Click on that and you will get all pages of assembly instructions in English and Spanish.
Posted on Mar 07, 2010
Anonymous
  • 3 Answers
SOURCE: can i get printable assembly instructions for a
Yes. Google Dorel Futons, look for the model resembling yours, and mouse click it. Under the Description paragraph, you should see a link for Instructions. It may be for a different model #, but remember they use different model #'s for different color cushions and slight variations in the frames. Good luck!
I need instructions to assemble a mainstay metal arm futon model #642
You will need to all the company that made his and ask them to send you a pdf file with the instructions.
Dec 07, 2016 | Furniture
How do I get assembly instructions for Wildon Home Corvallis Trimline Full Size Futon Frame?
You can contact factory direct or place you purchased from. Contact Us: 877-WAYFAIR (877-929-3247). I know the item is from Vietnam and instructions are not the best.i would lay out all your screws by size. Connect your back board to both end pieces withe the medium size screws. Then mount front board with long screws should be 4 for each side. Then assemble the couch lay down parts place on your assembled base. Uses washers on the long screws as this section swivels up and down. This reduces friction between the wooden parts. I hope this helps. Send your photos to mddoc13atyahhoodotcom. I will try to quite you. Attention Bob
Feb 01, 2015 | Wildon Home Corvallis Trimline Futon Frame...
Victoryland Black Metal Futon Frame assembly instructions
You should contact the store you bought the futon frame from and ask them to send you the assembly instructions or to give you the contact information of Victory Land.
Aug 24, 2012 | VICTORY LAND Shopko Victoryland Black...
I need instructions for a futon bunk bed I bought from big lots
Without knowing the exact model or manufacturer it's difficult to find assembly instructions, but the resources below may be helpful.
  1. Assembly Instructions for Round Tube Twin over Futon Bunk Bed (item no. SBP011-1): http://www.simplybunkbeds.com/images/pdf/SBP011.pdf
  2. General Bunk Bed Assembly Guide: http://www.bunkbeds.net/bunk-bed-assembly.html
Best of Luck!
Aug 15, 2012 | Coaster Black Metal/Dark Oak Twin Over...
Assembly instructions for a Cottonwood Provo Queen futon frame
I suggest that you contact Cuttonwood directly at 1-800-608-7507. You can also contact them through the website at: http://www.cottonwoodfutons.com/info/contact/
Jul 21, 2012 | Furniture
Need assembly instructions and bolt sizes for a twin over futon bunk bed
Can you find out the make of the beds?
If you can look it up on the internet and order the correct sized bolts.
IKEA is easy.
kolbrun
Feb 14, 2012 | Baby Gear
I recently bought a futon but for some reason if you fold it out into a bed and lay in the middle the futon folds up. I think it jsut isnt assembled correctly. Is there a manual to check for the Dorel...
I had the same problem, went to you tube and this guy has a wooden armed one very similar. I was happy that it shows step by step. Just type in assembly instruction futon, and it will come right up. Mind you, the parts are not exact but it was very helpful.
Jul 01, 2010 | Toys
Missing assembly instructions for Dorel futon FI310BLKS - thank you
Jan 24, 2010 | Dorel Alexander
Baby Gear Logo
102 people viewed this question
Top Dorel Baby Gear Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Dorel Baby Gear Expert? Answer questions, earn points and help others
