How to eject sd card from acer aspire
SOURCE: SD Card Reader Not Working on Acer Aspire 5600 Laptop
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
SOURCE: SD CARD is not working
I reccomend that if you can find a driver for your sd card slot, install it so that your slot could be compatible with all sd cards including HCSD cards.
SOURCE: acer aspire 5920 power turns off when sd card inserted into slot
This is most likly to be an internal fault, your laptop has saftety trips in it and if there is a short circuit or anything of the kind it will power itself off.
just going to have to wait out the 28 days, If you have an extended warrunty there is a possibility they will provide a courtesy laptop during repair, its unlikly but have a read through your documentation if you do.
Check to see that the SD card is inserted the right way, not upside down.
SOURCE: I'm using acer aspire one. My SD port is not
ok ... try this, switch on your aspire laptop, then u switch on your LCD multimedia projector... then u press the F5 key on your keypad(on your aspire) , HP, and many other manufacturers uses that key for the LCD,CRT,projector extension slot while other laptop manufacturers like Gateway e.t.c uses the F4 key for the extension... after you have done that... your aspire screen goes dim then it should show on your LCD...but if not then switch off your laptop with your LCD multimedia projector ON then swicth on your laptop it will automatically work with it ok.....
this applies to other laptops and projectors or LCD s ...
