Question about Franklin Industries FBC360D Beverage Cooler
Calibrate wine cooler display
Independent probe reades 42 deg F display reads 52 deg F
Posted by Jan Engle on
Can a wine cooler be programmed to go below 42 degrees
unlikely as 42 F is 5 C which is a tab above freezing
wine is kept cool not very cold so the wine cooler at 42 will be as low as is required to keep wine
Oct 03, 2018 | Furniture
Why does wine freeze?
Check for corrosion on the temp probe. The digital displays use thermistors to determine the temp so if the probe has dust on it it will change the resistance reading and tell the cooler that it is warmer than it is. All you can do is clean the probe, and if that doesn't solve the problem then the control or probe are faulty as they are usually one piece you will have to change it out. If you are mechanically inclined you can change out the temp control with an a19 abc24c remote bulb temp control from Johnson controls and that will last of the rest of your life.
Sep 05, 2014 | Danby DWC283BLS Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
How can I check the compressor relay? Is there a way to check and see if it's working?
If it rattles when you shake it it's bad.
There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing.Test the compressor relay for continuity using a multitester. Set the multitester to the ohms setting X1.
With the relay upside down, place the probes into the terminals labeled "S" and "M". The multitester should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up).
With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The multitester should now display an ohm reading of infinity (or the tester should not light up).
Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L".
The multitester should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity.
With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M".
The multitester should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms.
If the compressor relay does not pass all of these tests, it should be replaced.
Mar 03, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
On two recent occasions, my unit has chilled the wines down to about 36 deg.F. It has otherwise run fine for about two years, maintaining about 57 deg. F, consistently. Any idea what would cause such...
wine coolers are usually installed in cabinets or in a bar type situation where the airflow to them becomes more critical. the cooler has two sets of coils that can collect dust and dirt. once the coils clog with dirt, the fans cannot do there jobs by passing air over the coils. This is how the heat transfer takes place. One coil absorbs the heat from the inside of the cooler and the other rejects the heat into your home or outside of the unit. They should be cleaned once a month just like your refrigerator. This will make it run more effeciently. If this is not the problem, check to see if there is a supply register from your central heating and air system close to it. you may be able to get a diverter to push the air away from the cooler
Dec 05, 2009 | Transtherm Ermitage Wine Cooler
We got a Haier 42 wine cooler. The motor doesn't run.
This is something you can not fix yourself. Remember it might cost as much as a new wine cooler to repair. As for free estimate on repait. That way if it cost to much your not out anything. Rus
Jun 17, 2009 | Haier BC112G Wine Cooler
COOLER TEMP CONTROL SEEMS NOT TO BE WORKING.  TEMP GOES DOWN TO 42 AND STAYS THERE.
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Franklin Industries FBC360D Beverage Cooler Logo
50 people viewed this question
Top Franklin Industries Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Franklin Industries Refrigerator Expert? Answer questions, earn points and help others
