Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
How to work the sp750 heat control - Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Electric airhandler AC works fine heat only works in on position not auto
your tstat is set for gas heat not electric heat. there's either a switch on the back or it's in your configuration. you want the tstat to control the fan NOT the equipment controls the fan.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 16, 2017 | Heating & Cooling
2003 Pontiac Montana heat gets hot in front, blows but seems weak, and no heat on rear controls but blows ******* rear. what is going on?
Is your heater blower motor working on all speeds ? Are you get any air coming from the rear vents ?
Feb 25, 2015 | 2003 Pontiac Montana
Have a nutone 765hl-a heater blows but no heat
If the temperature control is turned up for heat but it is not heating, it is most likely a bad heating element or temperature control. Most heaters are not repairable.
Feb 19, 2015 | Dryers
My uniform cadet sp750 is not pumping ink from cartridges to dampers what could be the problem
  1. Remove the cartridge/s you have just installed and turn the printer off for 30 seconds. This resets your printer memory.
  2. Check the copper banding on each of the cartridges. This is their contact chip and what communicates with the printer. Give them each a gentle wipe with a cloth to ensure they are clean and dust free.
  3. Reinstall the cartridge to your machine.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Jun 04, 2014 | Epson Stylus Pro 4000-PS InkJet Printer
Chrysler lhs climate control
climate control requires the ac to work as well to vary the heat temperature and remove humidity from the cabin air. Check that the ac is working .
Dec 14, 2013 | Cars & Trucks
My kettle Hamilton Beach does not work. I push the switch and the light is on for 1 second and go off, but is not working.
please make this steps for test for fix it. God bless you
  1. Unplug the unit from the electrical outlet.
  2. For appliances with a removable cord, use contact cleaner, fine sandpaper, a small file or emery board, or a brass brush to carefully clean the terminal pins located where the cord connects to the appliance.
  3. Remove screws and/or clips to access controls on the unit or the removable cord. Clean the controls with contact cleaner, sandpaper, or file, being careful not to damage them or loosen parts
  4. Remove screws and/or clips to access the heating elements. Use a multimeter to test for continuity and replace any faulty element.
  5. To adjust the heat control, follow the steps below.
  6. To service the heat control, follow the steps below.
Adjust the heat control:
  1. Use a candy thermometer to verify the appliance's actual heat against its indicated heat. If the cooking appliance cooks with liquids (fry pan, wok, etc.), add water to the half-mark to test.
  2. Adjust the heat indicator on the control or adjust the temperature-adjustment screw (if available) to match the unit's actual heat.
  3. Recheck the actual temperature against the indicated temperature and readjust as needed.
Service the heat control:
  1. Unplug the control and open the housing. Set a multimeter on RX1 (resistance times 1) and touch the thermostat terminals with the probes. In the on position, the meter should read near zero ohms.
  2. Clean any contacts to remove food or corrosion, then polish with fine sandpaper or steel wool. If the contacts have only a little debris, use contact cleaner.
  3. If the heat control still doesn't work correctly, replace it with an exact replacement part
Nov 19, 2013 | Kitchen Appliances - Others
2009 Lincoln MKS heated seats do not work
there is a heat /cool control module under the drivers seat.
Jan 25, 2013 | 2009 Lincoln MKS
2003 escalade rear climate control no heat just cold air.
there are two separate actuators for the rear system. one controls temperature and the other controls vents from head to feet. mine problem was the later. that acutuator for esv 2003 is 89018365. it is located just below third seat cup holder passenger side and can be replaced simply by removing cup holder. triangular shaped part with wire harness.
Feb 25, 2009 | 2003 Cadillac Escalade Esv
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
47 people viewed this question
Top Qca Spas Pool & Spa Experts
john h
Tom Chichester
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
