Clarion DXZ645MP CD Player Logo
A
Anonymous Posted on Jun 09, 2014
I have a clarion ps-3103-da car radio from susuki vetara what colour wire go,s where
4 Related Answers
xmd1
  • Posted on Apr 15, 2008
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Anonymous
  • 239 Answers
  • Posted on Aug 19, 2010
SOURCE: Replacing Clarion Radio cassette in 200 Impreza
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Anonymous
  • 239 Answers
SOURCE: got a clarion db148r car stereo system but no
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
pls rate
Anonymous
  • 676 Answers
  • Posted on Apr 08, 2011
SOURCE: wich wires are - and + for a clarion car stereo
This should help you out. Good Luck.
2answers
Hi i need 4 numbers CODE for clarion CD Player PS-2367A-A
They gave it to you when the bought the unit. You will need to find the serial number on it and pay a company to sell you the code. This says 'FREE', but nothing ever is!
Get your free Clarion radio code online 2020
instant-radio-code.com > clarion-radio-unlock-code
If you have lost your clarion radio code or bought a used car stereo, you can still easily ... Almost all clarion radio codes consist of 4 to 5 digits. when your radio ..
https://www.google.com/search?q=4+numbers+CODE+for+clarion+CD+Player+PS-2367A-A
What other Clarion car radios are compatible with the wiring of the PS-2512 B model?
No idea.
Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
After power removal, the radio does not accept the correct code
You probably need to take it to the dealer to get the code. Unfortunately, they usually charge for it.
Ei-3103 vista drivers needed
download AC97 sound driver for vista and realtech ethernet driver for vista these are the to most common,  and install them
5helpful
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
1helpful
Clarion Suzuki Car radio code
ho una clarion ps-2685h serial n 0013004 è possibile avere il code? grazie
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
