Question about GE WSXH208A Front Load Washer
Excessive noise extremely noisy (very loud banging) at the start + all the way through spin cycle
Posted by Bobc02302 on
  • 3 more comments
  • jillwatts Mar 18, 2009
    I took the back off the washer, it sounds like a bearing is bad, but it also sounds like something clanking around in there. Tries to spin, but not doing a very good job. The noise is definitely coming from the back, inside the drum.
    Does the drum have to come apart or is it accessible through pulley area?
    I used to repair appliances years ago. I just have regular tools.
    Do the shocks wear out? It seems like it is settling. This is a different animal to me.
    Thanks, Mike.
  • aom_1950 Apr 18, 2009
    Is this reparable?
  • cmbls1 Apr 26, 2009
    the spin cycle is very noisy and out of balance regardless of what is in the drum.
  • fudge1223 May 05, 2009
    Same thing 2 year old GE FRont Load Washer don't expect anything help from GE can't even get the parts from CHINA!!!
  • Anonymous May 08, 2009
    The drum wobbles rather than floats like it should. It sounds like I am washing tennis shoes when I am only washing clothing.
Anonymous
I had the same problem. Two things were bad. One was the shock absorber and must be changed out as a pair. Also one of the springs that supports the tub was broken. My guess is that the spring broke and the shock failed shortly after. since it was more easily accessible and appeared to be the problem, I replaced the broken shock. Only to find the spring was broken too. After replacing the spring, its worked fine for a couple of years. Obviously I'm looking at this site because I'm having another problem, but this time I think it is the tub bearing.
Posted on May 13, 2009
Anonymous
    Champion:
  • 249 Answers
Drum bearings gone
Posted on Nov 22, 2007
Washer makes a loud banging noise when in the spin cycle. Very noisy!
Make sure the load is placed inside it in an even manner. not out of balance.
Jan 19, 2017 | Washing Machines
GE front load washer model number WBVH6240HWW SERIAL NUMBER RM200099T spins freely by hand but started smoking and belt behind looks fine. What could be the problem. Before the smoke started when spin...
Hmm... Kind of difficult to say for sure. Does your inner spin basket wiggle up and down? If so, you've got a main bearing going. Also, put it in a spin cycle for a minute or so and then try smelling the windings on your main motor. If they smell burnt, you'll need to replace the main motor. Also, one last thought, check to see if your drain pump overheats. I say this because the drain pump is active during the spin cycle and a bad drain pump can sound extremely noisy and start overheating.
I hope this helps. Good luck!
Oct 19, 2014 | Washing Machines
My LG Intellowasher M-1480FHD has started making a loud banging noise on the final spin. It also wouldn't end the spin cycle at the end of the 30min wash
the banging noise while in the spin cycle will more than likey be worn shock absorbers and will need replacing.
Aug 31, 2010 | Washing Machines
My frigidaire front load washer/rear control panel GSTR1670AS0 just started to make a VERY LOAD banging noise. I replaced the belt, but it is still noisy and then got the same banging result during the...
Could be Drum bearings, try Grabbing the inner drum and moving it front to back ,should have little or NO Play, assuming this is okay then check the counter weight, Concrete Slab on top of machine outer drum loose
Dec 06, 2017 | Frigidaire GSTR1670A Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Makes a loud banging noise as if the load is underbalanced even through the load is balanced.
HI There
Try this even tho you said it's balanced. Sometimes it looks like but a slight unbalanced can cause this problem.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Let me know how this goes and thank you for writing to fix ya.
Best Regards Richard
Jan 07, 2010 | Kenmore Washing Machines
In spin cycle, there is a loud metal on metal sound. could it be a bearing going out? the machine still spins but much slower, and the banging sound occurs in one place every revolution during the spin...
Hi
Remove the drum belt, and spin drum by hand.
If it feels rough, or it is noisy, then drum bearigs have failed.
Please rate my solution.
thanks.
Jul 24, 2009 | Whirlpool Washing Machines
Washer spin cycle extreme vibration and loud bang when it stops
check the vibration damper rods for breakage - especially the mounts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
GE WSXH208A Front Load Washer Logo
703 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
