Hi. To transfer your photos from your computer to your Hudl 2, connect you charging cable to your computer. Make sure that your Hudl 2 is show under the 'My Computer' page of your folder section. Then select your phots and drag the into the Photos folder of you Hudl 2. This can be found by double tapping the Hudl 2 icon on your pc.
I hope this helped.
According to Salivat Gairdner, below is How to un-freeze your hudl.
Turn over your hudl and search for a hole. Once you've found it, find a pen or pin and push it in. The hudl's screen should turn off. Turn the hudl back on using the power button and your set!
How to fix the freezing bug
Tesco has released an update which includes a setting in the Display section. It should automatically install, if it doesn't go to Settings then to About Tablet. Click on System Updates and wait for the hudl to find the update, if it does find one - leave it be until the installation has finished. Once it's finished, go back to Settings then to Display. Click on Reset touch screen, this is what causes the hudl to freeze. Click on Reset screen and your done!
You should just be able to plug your HUDL in and it should begin charging. Check that the outlet you're using is providing power (try another outlet too).
I'd recommend getting in touch with Hudl directly should you need additional support, I've included their support page below:
A Print Spooler is like an electronic sponge when squeezed it will expel data slowly from one source to another. This is driven by Printer Drivers that associate with the computer and a receiver/sending device like a modem or router. If the signal fails from the Router to the Printer, the loss means the data was slowed down and may or may not reach the printers receiver and thus pages cannot be duplicated.
Almost all email or data base contacts can be exported as comma delineated text files Are you able to do that kind of thing? If not I can not give you good step by step without knowing from what OS and application you are exporting the data from. Then I would need to know what version of OS is in that hudl.
Go into system to Language and input.
Click on the UNTICKED Google Keyboard English-box at right of page.
If its like my mark 1 Hudl or my wifes Hudl it then shows a Language screen.
Go back and double click the above and go down to text correction where you can either switch off or adjust the sensitivity of the predictions.
Once you have done this a single screen click shows you this "missing"screen.
If you totally dislike the Google keyboard then go into language screen and choose Qwerty keyboard.
