Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Kenmore coldsport refrigerator door not closing properly
2 Related Answers
Anonymous
SOURCE: Kenmore refrigerator door will not close completely
Both top and bottom doors will not close on mine
Posted on Feb 19, 2009
mario3246
Mario3
  • 56 Answers
SOURCE: Kenmore Coldspot 106 door needs aligning not closing properly
Try to search for the solution within the manual: Kenmore Coldspot Model 106 Manual
Posted on Nov 17, 2013
One door on my French door Kenmore elite refrigerator won't close properly
It may be out of sync with adjoining door or may need and adjustment. Thank you. We may need a photo. Please leave feedback!
Jul 10, 2016 | Kenmore Refrigerators
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
Lights will not go out when I close Kenmore elite refrigerator
Hello John, the door switch is stuck in the on position. It may be possible to lubricate it with a squirt of PAM cooking spray, or it may have to be replaced.
Oct 02, 2009 | Refrigerators
Water leaking from the roof of the fridge inside.
That is condensation. The rubber insulator (gasket) on the door may be damaged or worn. The door does not close and seal properly.
Make sure that nothing that is on top of the refrigerator is "hanging" into the path of the door seal (like a bread bag ponytail).
Also to consider:
Door hinge is loose so that door is not aligned for proper door seal.
Refrigerator is not "level" so that door is not ...
Freezer is defrosting (heating elements will warm up the coils, so "dew point temperature" may have been reached.
Check the door gaskets.
Sep 21, 2009 | Kenmore Refrigerators
Kenmore Trio refrigerator doors will not close properly
call a repair service only a person with hands on capability can help you
Oct 07, 2017 | Kenmore Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
162 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
fpreston
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
