Question about Lenovo IdeaPad Z480 Laptop Computer - 21484AU - Red - 3rd generation
Touch pad problem - Lenovo IdeaPad Z480 Laptop Computer - 21484AU - Red - 3rd generation
ernaserlikas
    New Friend:
  • 42 Answers
Download all Windows updates with touch pad drivers.
Posted on Jan 08, 2016
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
How do i activate my touch pad on my compaq notebook 515
If you look at the touch pad there on the touch pad of near to it you will see the button to unlock the touch panel
Aug 18, 2011 | Compaq (153515-001) Touch Pad
HOW TO CHANGE THE TIME ON A Technika CR-109IP
1)touch and hold both the M and E touch pads for at least 1 second to enter clock setting mode
2)set the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the number
3)when the hour is set correctly touch the E touch pad to confirm
4)the minute digit will now flash. set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
5) when the minutes are set correctly touch the E touch pad to confirm
the clock is now set
Sep 19, 2010 | Audio Players & Recorders
My toshiba satellite A355D touch pad is not working. my husband told me that probably my kid turned it off. if that is the case... how can i turn it on?
Sounds like your touch pad may need to be replaced.You can't really turn off the touch pad.Even if your child managed to uninstall the touch pad it would load back the drivers at next startup.Chances are the touch pad will have to be replaced.Its possible the touch pad may be disconnected from the motherboard but not very likely though.
Aug 24, 2010 | Computers & Internet
Scroll is not working
This could be one or some of the 3 issues that may be happening with your notebook or netbook:
1) check control panel (if this is windows) and click on touch pad icon and make sure the sofware to control the touch pad is working and it's on.
2) If it is on, reinstall all touch pad and mouse drivers for this unit by going to the manufature's website and downloading the original drivers for this unit
3) it that does not work, you may have a defective or broken touch pad and it may need replacing
BEFORE CONTEMPLATING A NEW TOUCH PAD, do 1 and 2 first.
They are usually the main causes of touch pad failure and should resolve your issue.
If both fails you may need to order a new part to replace the pad.
I hope this helps. Write me back and let me know how it goes
Jun 14, 2010 | Compaq (153515-001) Touch Pad
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Dell touchpad tab gone from mouse settings. tried installing driver with no luck. Also tried uninstalling and reinstalling driver.
Customizing the Touch Pad
You can use the Mouse Properties window to disable the touch pad or adjust
the touch pad settings.
1 Click Start , and then click Control Panel.
2 Click Hardware and Sound.
3 Click Keyboard.
4 In the Mouse Properties window:
• Click the Device Select tab to disable the touch pad.
• Click the Touch Pad tab to adjust touch pad settings.
5 Click OK to save the settings and close the window.
Apr 06, 2010 | Dell Studio 17 Laptop
Touch screen not working help me
the touch pad of your phone is faulty it needs to be replaced.
To replace the touch screen, you need to get a new touch pad.
When you purchase the new touch pad,you have to loose the phone to gain access to the faulty touch pad.You will needing a soldering iron to replace the touch pad.
If you do not have the technical know how of fixing the touch pad, i would advice that you give it to an expert so that you will not damage anything further.
Have a nice day.
Mar 15, 2010 | Sony Ericsson P900
Disabled touch pad
you must re-download and, re-install the driver software again
Apr 29, 2009 | Computers & Internet
I have the inspiron1520 laptop, I want to dissable the touch pad. I only use an external Mouse. Regards Geoff Grigg
You can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg, and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
  5. Click OK to save the settings and close the window.
Please rate this solution.
Sep 20, 2008 | Computers & Internet
Lenovo IdeaPad Z480 Laptop Computer - 21484AU - Red - 3rd generation Logo
42 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
