My Stanley tank sprayer doesn't need to be pumped. I can't make it stop spraying
SOURCE: pressure no spray on 1 gal tank
try removing the tip and cleaning it. there maybe something stuck in it even if its new. if that dont work i would take it back to where i bought it. hope that helps
SOURCE: I have a 3 gal. back sprayer. When you try to
Hi there
There are many possible reasons for your sprayer not pressurizing. If the pump lever is moving freely and does not seem to be building pressure while pumping it is possible that the O-ring at the valve is damaged, the seal in the pressure regulator is leaking, the piston or the collar is worn. Any of these problems will require disassembly of the unit and inspection of each part. If you do feel resistance building as you pump but quickly loose pressure you likely have leaks in the diaphram, it's seal, the pressure cylinder or the tank itself.
If you are comfortable disassembling the unit and inspecting the parts for wear or damage most of the individual replacement parts are fairly easy to replace and readily available online from Solo or at many retail outlets and supply companies. Solo has done a great job with how-to videos and instructions for each procedure on their web site www.solousa.com
If you are not comfortable disassembling and repairing your sprayer yourself you can try contacting a mower/equipment repair shop in the Redding area as is seems the nearest Authorized Solo sprayer repair center is Cloverdale Saw in Cloverdale CA, 707-894-2273
SOURCE: Ortho 2 gallon pressure sprayer has pressure but no spray
I had the same problem and had to take apart the handle portion and found that there was something in the line at that point. After cleaning it I had the same pressurse as when it was new.
