Breville CT20 Retro Classic 2-Slice Toaster Logo
A
Anonymous Posted on Jun 08, 2014
Why won't my breville toaster depress - Breville CT20 Retro Classic 2-Slice Toaster
2 Related Answers
Anonymous
  • 87 Answers
  • Posted on Jul 12, 2008
SOURCE: Breville classique toaster
burned out element . replace unit.
Anonymous
  • 5 Answers
  • Posted on Mar 28, 2011
SOURCE: breville toaster bta840xl manual
http://www.scribd.com/doc/20862186/Breville-BTA840XL-Manual
Breville toaster oven start button
Try some electrical contact cleaner. Tip the machine on its back.
How To Fix Breville Toaster Oven Start Button: 2 Solutions
https://splaitor.com > How To
Feb 9, 2021 - If your Breville toaster oven board is warped, your oven Start button doesn't work properly. The most common problem is when you press the Start ...
More here
https://www.google.com/search?q=Breville+toaster+oven+start+button+replacement
2answers
Breville toaster oven - beeping and Code E05
According to sources, breville toaster oven E05 LCD error is non-resettable issue. You should immediately turn off your toaster oven and remove the power plug. After doing so, call breville customer care. Hope it helps!
Right side lights on all buttons won't stop flashing and bread 'holder' stays closed
Hi! Try to unplug it from the electrical grid and to clean it inside the place where the bread goes, maybe there's a piece of bread stuck in there. I hope this will work! Have a nice day!
Tthe lever on my Braun HT 600 toaster won't stay down. 3 years old, but very moderate use. Ideas?
Be sure to unplug toaster first. While inverting your toaster, depress the toaster lever(s) and shake toaster to clear all bread crumbs. It can take up to several minutes of shaking to clear them completely, however, the key is to depress the toaster levers down at the same time. Also, remember to remove bread crumb trays and empty regularly, as the trays are too shallow and allow crumbs to build up quickly, thereby blocking the "locking mechanism" of the lever(s).
If after cleaning your toaster out thoroughly, the levers still won't remain depressed, try various outlets throughout your kitchen. Oftentimes, when one GFI (Ground Fault Indicator) trips, several outlets along the same circuit will also trip.
Also, there is a website called Manuals.com, which has a very good database of many manuals for various manufacturers and models of toasters, should all of the above efforts fail.
I did all of the above and fixed my toaster within five minutes. :- )
Good luck to you.
Yvonne
I need an operating manual for the Breville convection toaster oven
Hi there.
You will be able to find Owner's Manual of Breville Convection Oven at http://www.breville.com.au
Regards.
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Could you tell me if this toaster has a 3 prong plug in?
The Breville BTA840XL Die-Cast 4-slice Smart Toaster is grounded and has 3 prongs.
I hope this helps.
I need instructions for Toaster VTT090
Below the only manuals for toasters available from breville.
Sandwich Toaster
Die Cast Model
Ikon model
Hope they can help
2answers
Just fixed my Breville CT20. Cleaned the contacts, there were no impeding crumbs so I tested again and still wouldn't stay locked. I finally replaced the 470uf 16v capacitor on the control board just below the electromagnet and wow, works like a brand new toaster! I got lucky, saving bits and pieces of old circuits sometimes pays off.
Top Breville Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
yarik117
yarik117
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
