Question about Olympus Camedia D-395 Digital Camera
How do i get out a stuck sd card from a olympus D-395 camera
I was trying to find a SD card that could fit in the camera, then the SD card got stuck and I can't get it out. Please help.
Posted by victoria brown on
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
SOURCE: SD Card or Memory card
Hi - You can download the manual by clicking the link underlined in blue below:
C 3000 Zoom
See page 231:
So the camera takes SmartMedia cards not SD.
An eBay search found 84 cards for sale in my area, also try Google for other suppliers near you.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 23, 2008
Anonymous
  • 919 Answers
SOURCE: i have d 395 olympus
The problem is that the largest xD card that your camera can support is a 512mb card. The firmware in the camera cannot support memory storage with cards that have the letters M or H in front of the 512mb. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Posted on Feb 03, 2009
Anonymous
  • 919 Answers
SOURCE: how do I use micro sd card in camera
What is the orange "card" bundled with my camera and how do I use it?
The “card," pictured below as packaged, is the MASD-1 card adapter.
The MASD-1 accepts microSD and microSDHC media, giving owners the option to record to those cards or to xD-Picture Card media, which is Olympus’ preferred format.
To use microSD/SDHC media in the camera, simply insert the card into the adapter and then insert the adapter into the camera's memory card slot.
Posted on Mar 19, 2009
Anonymous
  • 919 Answers
SOURCE: problem with olympus digital camera d-395
The problem is that the largest xD card that your camera can support is a 512mb card without the letter M or H in front of the 2gb. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there are no plans to upgrade the camera to allow those types of cards to be supported.
Posted on Apr 30, 2009
Anonymous
  • 109 Answers
SOURCE: new xd picture card compatability with olympus d-395
Check the maximum capacity memory card that your older camera will take. My Fuji will only take up to a 2gig card unless I flash the firmware in the camera to take the newer 4gig cards. Some of the older cameras maxed out at 1 gig or less. Check eBay for smaller capacity cards as they are getting hard to find in stores.
Posted on Jul 20, 2009
What size sd card fits in the Olympus c 2100?
SD cards don't fit as it is smart media ?ards that it uses
Which are rated in MB not GB
Jun 17, 2015 | Olympus Camedia C-2100 Ultra Zoom Digital...
Have "olympus sp 800uz" and
1. Put the SD card into the computers cardreader.
2. Connect the camera through USB with the computer .
3. Copy the pictures.
If you have trouble with the SD card:
1. Copy all the pictures to the computer.
2. Format the sd card in the camera.
3. Copy the pictures back onto the sd card.
Aug 31, 2011 | Olympus SP800UZ Digital Camera
What type/size memory card does it use? I have bought this camera but cant find the type of memory card device that fits. All that is in the market does not fit. Please give the serial number of the...
It use micro SD card or micro SDHC. You can use also Transflash (TF) with SD adapter.
Please don't use other cards. Be carefully while inserted the card, do it by right orientation.
Jul 31, 2011 | Olympus FE-46 Digital Camera
The instructions say to use SD/SDHC memory cards only. I purchased an Olympus x-D picture card M+ 2GB. Is this a card I can use? I do not know what the difference is.
No, if the instructions say that it will only take a SD or SDHC card then that is what you must use. They are different shapes, with different contact layouts, and different formats. They are not compatible with each other unless the devices specifically supports it.
Here is what a typical SD card looks like: crasher35.jpeg
Compared to the xD card: crasher35_17.jpg
They generally will not fit in each other's slots.
May 29, 2011 | Olympus Stylus 5010 Digital Camera
Olympus SP800UZ Digital Camera Media card will not lock into card slot, it comes right back out!
Put in another SD or SDHC memorycard to test if it is the camera or the memorycard which is faulty. Are you sure you put in the correct type of card? Only SD / SDHC will fit correctly in the camera.
Dec 30, 2010 | Olympus SP800UZ Digital Camera
My olympus is not reading the SD cards. I thought it was the card because the camera said "card error" when I put it in. I tried two other SD cards and the camera says "no card". Any...
Your camera uses xD cards, not SD. Now if you are using a micro-SD adapter, make certain that the cards you are using are 2GB or less standard micro-SD cards. Your camera will not work with 4GB or larger micro-SDHC cards as that format had not yet been invented when your camera came out.
Dec 23, 2010 | Olympus Camedia C-310 Zoom Digital Camera
The SD card from my Olympus camera does not fit into my new ViviCam 5022. Does it have to be a certain brand of SD card?
Is it actually an SD card? The Vivicam 5022 accepts SD cards up to 8GB (which means SDHC as well), but many Olympus cameras use an XD card, which is quite different. SD and SDHC cards are all the same for fit, regardless of brand.
Nov 22, 2010 | Vivitar ViviCam 5022 Digital Camera
Olympus FE-20 isn't noticed by computers
Make sure the camera is on and the batteries are fresh before you connect to your computer.
Not all usb plugs are the same. You may need a specific one for your camera.
Also you may try taking the sd card to a photo shop like Walmart. They may print the picture for you.
Dec 20, 2009 | Olympus FE-20 Digital Camera
The camera says xd and sd compatible but it seems that the card is getting stuck and wont fit into the slot for the card?? any ideas why? i just bought the camera 2 days ago
The camera has one xD slot, and is supplied with an adapter which fits into the slot if you wish to use micro-SD cards. Regular SD and mini-SD cards will not fit.
Jun 29, 2009 | Olympus FE-25 Digital Camera
Olympus Camedia D-395 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you an Olympus Camera Expert? Answer questions, earn points and help others
