Philips 32PT6441/37 32" TV Logo
Question about Philips 32PT6441/37 32" TV
Philips 32PFL6407D/F7 menu popping up uncontrollably
The tv turns itself on to cycle through the startup menu. I can't control it and the volume sometimes plummets and can't be raised, the tv cannot be controlled during this cycling and even turning it off doesn't keep it off.
Posted by julialee23 on
5 Related Answers
Anonymous
  • 1284 Answers
SOURCE: TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Posted on Feb 05, 2007
Vista Electronics
  • 1694 Answers
SOURCE: Philips 29PT9418/69G
A qualified tech will need to practice visual acuity technique! Look at power supply circuit for signs of stress,dis-coloration and/or bad connects.Check for bad 47mf/25v cap in area of stress.Replace BC-327-25 xistor w/BC-328 and replace BC-337-25 w/BC-338,if present in your set's chassis style.
Posted on Sep 25, 2007
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
Anonymous
SOURCE: volume controls don't work
Remote Batteries?
Posted on Jul 26, 2008
Anonymous
  • 41 Answers
i am not sure but that would scare the **** out of me
Posted on Jun 03, 2009
My Philips 46PFL3608/F7 tv remote will not work. I can only manually turn on the tv and control the volume from the back of the tv. No controls work from the tv remote. Batteries have been replaced in the...
If multiple remotes used to work (your xfinity and the one that came with the tv), and don't anymore, my first thought would be the issue is with the TV and not the remotes. Is there something physically in the way of the infrared sensor on the TV? Often the sensor is on the at the bottom of the screen on the front, so if your TV is on a table, it's easy to set something in front of it.
Aside from that, there's the normal troubleshooting stuff, see attached images.
remote_troubleshooting2-xpnqcryvoxbslrst3kzoppjq-4-5.jpg remote_troubleshooting4-xpnqcryvoxbslrst3kzoppjq-4-9.jpg
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
2answers
I have a philips 40pfl3705d/f7 LCD TV and the volume can be seen onscreen adjusting itself randomly. Tuns on and off by itself and so on all by itself. When it works it works great. But randomly it seems a...
You might need to get this checked with the manfucaturer, looks like a malfunctioning remote control. Or you can just replace the remot and see if that helps.
Philips TV 42PFL7403D/F7 Remote no longer controls Volume & ON/OFF
you can start with opening the remote control and clean the buttons on your remote control. don't use any aceton based products. there can be some grease on the buttons.
if you used the on/off and volume more then the other buttons.
1helpful
2answers
The remote control works sporadically and when the TV is turned on or is bumped, the menu and volume displays flash on and off on the screen. What can I do to fix it?
NO, your remote control sounds like it is sending the signals to the TV. Take the batteries out or put it in a drawer to test. If it's the TV doing it itself, then it's a bad remote receiver circuit.
My 37" LCD Philips TV has mind on its own.
your internal controller board is going bad in lcd
Help!
I don't know if this will help your problem, but we were having similar problems with our Toshiba 32A33. None of the buttons on the TV or remote worked, the volume would go up and down uncontrollably, it wouldn't turn back on unless unplugged for several hours
Try either taping a penny very firmly over the TV/video button on the set to keep it depressed at all times, or wedging a piece of plastic in it to keep it down (Cardpsycho's solution).  However you do it, keeping this button depressed solved every problem we had.
2answers
I have a new Philips tv that did the same thing on me I left it off for a couple of minutes and that seems to work
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
