Nabi 2 Logo
C
Cutelyn Morgan Posted on Jun 08, 2014
How to reset nabi 2
I cannot get the internet on the nabi it is saying select imput method and there are some options i selected english (UK) and I am stuck i cannot go any further what shall i do
brian
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Jun 08, 2014
brian
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
4244
Points
43
If you haven't done this already, hold down the power button for like 10 seconds to reset the system.
How do I reset the nabi tablet.
  1. Turn off your nabi Big Tab.
  2. Press the Volume - button first, then press the Power button and hold them both until the system menu appears on the upper left corner of the screen.
  3. Use the Volume - button to highlight "Recovery Mode," then press the Power button to select it.
More items...
I Need to Perform a Factory Reset on My nabi Big Tab
https://www.nabitablet.com/.../nabi.../i-need-to-perform-a-factory-reset-on-my-nabi-big-... How do reset the nabi tablet Google Search
I am trying to set-up my new Kindle and everything is in Spanish. I need it in English. Help!
From the Home Menu swipe down to get the pull down menu. Select the gear on the right hand side which is Settings. Select the Language option which may or may not read Idioma in Spanish. If the menus are in the same order as in English it should be immediately after the Keyboard option which may read Teclado. The first option under Idioma sets the language for the table. Select the first option. If those options are in English select English, if they are in Spanish it should say Ingles.
1helpful
On my new Kindle Paperwhite - language is Spanish --I need to have the language in English
You can change the language by taking the following steps:
1. Tap the menu button(Icon of 3 vertical lines on the top right of the screen)
2. Tap settings(The 6th option)
3. Tap Device Options(The 4th option)
4. Tap language and Dictionaries(The 5th option)
5. Tap Language(The 1st option) and select English(UK or US) from the list.
6. Press OK on the top up window to restart your Kindle and the language will be set to English.
I have a Nabi that all of the sudden even if the green light is on saying its charged the screen stays black
Sounds like you have a good charger/cable, so try resetting the Nabi that's giving you trouble. Hold the power switch down for 10-20 seconds to reset the unit.
I have a couple of NABI-2 tablets and they both react differently to the charging cables; I often have to shut the NABI off completely to charge them. Also, getting the charging cable to connect can be challenging - I will plug the cable in and out several times waiting 10 seconds or so to see if the green LED will go red.
Dec 31, 2014 • Nabi 2
I received a gift the I craig 9 inch touch screen tablet model: CMP756 I followed the directions set up when finished shut down when I turned it back on it is stuck on loading screen and won't procced to...
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
Costumer support
Data will be lost so first press the back up option and take a back up into sd card
If/when you're on the Android System Recovery screen release all the keys, and then use theVolume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
How to do hard reset on hcl me champ tablet?
It was stuck on android loading....?how do i fix it?
Use below method : but it will cos you data which is attached to you tablet internal memory
1helpful
FORGOT PASSWORD
only option is hard reset
switch offf your tab
hold the volume up button and keep pressing power buttun repeatedly
it'll ask for foctory reset put yes
Top Nabi Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
techy
Level 1 Expert
Ari Garcia
Ari Garcia
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
