Question about Sony KDS-R50XBR1 50" HDTV
I thought the bulb was bad. replaced still does the same thing. could the ballest be bad? how to test Please.
SOURCE: REPLACED LAMP
The switches (there are two of them) can be bypassed but it isn't a fun job. There are 3 connections on the switch boards and if you connect all 3 together, that should bypass the switch. There is one switch on the door and another located on the lamp socket board. You can bypass on the door but there is no way I can describe how complicated it is to get to the one on the lamp socket. So, try jumping the one on the door and see if helps. REMEMBER THAT THE LAMP IN THIS SET CAN CAUSE BURNS, VISION DAMAGE AND OTHER PROBLEMS SO AFTER YOU HAVE JUMPED THE SWITCH, PUT THE DOOR BACK ON AND MAKE SURE YOU HAVE THE CORD UNPLUGGED WHEN YOU WORK ON THE TV.
Posted on Nov 15, 2008
SOURCE: XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
Posted on May 30, 2009
SOURCE: KDF-E42A12U - Three Standby flashes???
There is the possibility that you might have a defective ballast, it might not have enough voltage to keep up with your new lamp, and that's why it switches off and makes the 3 indicator lights flash, letting you know that the bulb is defective, but it's not the bulb, it's the ballast
Posted on Jul 14, 2009
SOURCE: sony wega kf-ws60s1 , standy by lamp flashes 6
thermal fuse by lamp is open. replace it.
Posted on Dec 08, 2009
SOURCE: kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Posted on Feb 08, 2012
Jun 08, 2014 | Televison & Video
Aug 01, 2017 | Sony Televison & Video
Mar 04, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Mar 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
Oct 15, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Jul 17, 2009 | Samsung HLS4676S Television
Jul 13, 2009 | Sony Televison & Video
Jun 14, 2014 | Sony KDS-R50XBR1 50" HDTV
