Question about Vulcan AUW230A Heater
Where is the polit light on a valcon bonair
The poli light has gone out and we don't know where to find it to relight it
I have a Brivis buffalo 26 unit...the heating is on but it's blowing cold air the pilot doesn't seem to be light but I don't know how to relight it!
Try adjusting your thermostat, contact point possibly melt and welded by electric sparks. Replace thermostat control if contact won't get open.
Sep 02, 2011 | Heating & Cooling
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
My corsaire furnace does not always ignite sometimes it just blows cold air. what should I check?
Hi there
I read your report. sounds like your polite need's to be clean. try this tip. Take a paper clip and clean out the polite real good then try to relight it again. If it's still not light. check your control valve and your regulator valve. it'll be one of those two things. Let me know how that went.TY for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | Heating & Cooling
Pilot light gone out. How do I relight? Which
In general, large button from gas valve push in & hold 20-30 secs at same time push electronic lighter/ignition button to light pilot. Remember to hold in only gas button. the pilot light heats up a thermo couple [u can see this in the flame] and when hot enough allows the main gas through and the pilot to remain on.
If not then either thermo couple not heated for long enough or
it may need replacing
Oct 22, 2009 | Bosch Water Heaters
The pilot light on the oven has gone out, how
called the company which I bought it from and they are coming to fix it, it is the ignitor that is bad.
Oct 13, 2009 | Maytag Kitchen Ranges
My pilot light also just went out on my water wizard 13P when you relight ensure all buttons are equal in height or none depressed then hold far left button down whilst striking ignition button till pilot light ignites keep left hand button depressed for a further 3 seconds after pilot light has ignited I hope you have hot water then
May 22, 2009 | Audiovox Bosch 718 World Cellular Phone
Vulcan AUW230A Heater Logo
Top Vulcan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Vernon Taylor
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
