Philips CDR775 2-Disc CD Recorder Logo
A
Anonymous Posted on Jun 08, 2014
How to re-calibrate philips cdr 775 - Philips CDR775 2-Disc CD Recorder
3 Related Answers
Anonymous
  • 32 Answers
  • Posted on Jan 06, 2009
SOURCE: i nead a new manual for a phillips cdr 775 dual recorder
http://www.usersmanualguide.com/philips/home_audio-video__cd_recorders/cdr775_00
Choose your specific model and language. Downloads in pdf format.
Good Luck,
BB
Anonymous
  • 6784 Answers
  • Posted on Jun 03, 2009
SOURCE: when i play cd's the player frezzes
Hi, the tracking motor on the lens Assembly is faulty, you will need to either replace the tracking motor or the entire optical lens assembly.
Anonymous
  • 8546 Answers
  • Posted on Feb 12, 2010
SOURCE: I trying to hook up My philip Cdr 775 to a denon
Depends on what you want to record and what capabilities the other equipment has - analog audio passed through the Denon and/or digital audio from it or another device, like a CD player. There are both Inputs and Outputs.
Treat it like a tape deck: It will have analog input from the receiver's Tape Out jacks and it will send analog playback and monitoring to the receiver on the Tape In jacks. (Page 14)
Ditto for compatible digital connections. (Page 15)
You can find the manual on Retrevo.com. Just register and download it. You're going to need it to make use of the machine anyway.
2answers
Where can i buy a CD-RW Audio(rewritable) for my CDR 775 Audio Cd recorder?
Web search for them, check eBay. ANY media that has 'digital audio' in its description will work. They don't have to be re-writeable.
"cd-rw audio discs"
2helpful
2answers
I have a CDR 765 Philips recorder. It doesn't work on recording. The error message is "NO OPC". Thank you
hola
la cdr765 de philips es una grabadora de pc 3610 de philips o hp7200, el opc error es la lente esta mal, compra ina grabadora y cambia los 2 circuitos de la mecanica original de la cdr765 y desmonta la 3640/7200 y ponle los circuitos montas y a disfrutar.
I have the OPCFASIL problem on a Philips CDR 760. Tried many disks, gave up. Does anyone want this unit? Free. Just pay for shipping.
ma platine laser philips 760 elle dit qu'il n'y a pas de disque puis elle annonce le total des disques j'appuie sur le premier elle ne d?marre pas g achet? une 775 d'occasion je vais br?l? un cierge ...
WHAT IS AN OPC ERROR?
Hi,it means It implies a "media Optical Power Calibration problem".
Use this link as a guide...
gallagher.com/music/cdr.htm
Hope it helps. You can pass on your comment.
Thanks for using fixya.
3helpful
3answers
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
1helpful
When i play cd's the player frezzes
4helpful
2answers
Laser is malfunctioning on my Marantz CD Recordable DR6000
the laser in your DR-6000 is exactly the same as what's in the philips cdr-775 and cd-r-770.
a brand new laser for these are very hard to get hold of and are very expensive. personally i would look out for the above philips models on ebay for less money then take the whole mechanism out and unscrew the servo board and then fit the marantz servo board in place of it and fit it back into your recorder.
i have done this on numerous occasions with no problems.
hope this helps.
1helpful
I nead a new manual for a phillips cdr 775 dual recorder
Good Luck,
BB
2helpful
Do you do stock spares for the CDR775?
I've some spare parts of CDR 775. Power suply and two drives also. Small bit cables etc.
thanks
Dainius
[email protected]
1helpful
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
