Question about Electrolux EW1000i Front Load Washer
E31 error code on electrolux washing machine
How to I fix this error???
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Posted on Jun 12, 2014
6ya staff
SOURCE:
Anonymous
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
Anonymous
  • 750 Answers
SOURCE: error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
Posted on Oct 16, 2008
e-Guru
e-Guru
  • 3917 Answers
SOURCE: error code e40 on my washing machine electrolux
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
Posted on Aug 06, 2009
Anonymous
SOURCE: Electrolux ewf1087 washing machine error code?
what is a (e40)
Posted on Jan 02, 2010
Anonymous
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
How to clear error 2 on a fully automatic toshiba washing machine
Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
https://www.skypesupports.com/
May 30, 2018 | Washing Machines
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E21: Lid open
E31: Load imbalance
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Washer won't start showing code E31. Already changed pressure switch an cleaned drain. Is there a way to reset?
error code e31 frigidaire washer Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your error code e31 frigidaire washer question. ... error code E31, first check if it is a false error code by resetting the power to the appliance by ..
Jul 28, 2015 | Washing Machines
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
Jan 25, 2014 | Washing Machines
White westinghouse dryer
Hello Mizar - Thank you for allowing me to assist you. If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 29, 2013 | Electrolux Dryers
E31
Hello Stephanie - If you are receiving error code E31, first check if it is a false error code by resetting the power to the appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, it could potentially mean a number of things: a pressure sensor issue, defective wiring, valve assembly problem and/or control board issue. I would strongly recommend connecting with an expert technician to assist further.
May 02, 2013 | Frigidaire Affinity ATF7000E Front Load...
My Electrolux washing machine W4180N has faul error 6 (e6), how to fix the problem
I'm not finding anything in my literature on that code. I would contact electrolux directly.
May 30, 2012 | Electrolux W4180N
Error Code E31
search for error codes thru Google your MAKE
Sep 21, 2017 | Washing Machines
Error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
huuum
Oct 15, 2008 | Electrolux EW1000i Front Load Washer
E31 error code
Did a little search and this is what I've found. http://www.fixed4free.com/answers.php?id=30722 Goodluck.
Aug 29, 2006 | Zanussi FJD1666W Front Load Washer
Electrolux EW1000i Front Load Washer Logo
1,375 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
