SOURCE: Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
SOURCE: Door locked after power surge/failure
The question here is how long did you leave the breaker off? Gaggenau ovens have a memory and I always advise turn the oven off for 5 mins before turning the breaker back on. Give that a try. The first thing the oven does when the power is reapplied is go thru a test phase which included locking and unlocking the door. The key symbol will go on and off during this. Sometimes you have to also can run a self clean then cancel it to reset the lock. This works as well.
SOURCE: error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
SOURCE: The temperature switch on the Gaggenau EB 270/271
http://www.gaggenau-eshop.com/eshop(bD1lbiZjPTAwOQ==)/gaggenau/us/indexs.htm?Refresh=Y
http://www.gaggenau-eshop.com/eshop(bD1lbiZjPTAwOQ==)/gaggenau/gb/prodp.htm?prod=EB270220%2f01&ESHOPTYPE=S
Not sure what country you are in but the 1st link is US and the 2nd link is UK.
Hope this helps
