Question about Tag Heuer Formula One
My watch has stopped, how can I fix it - Tag Heuer Formula One
Stop watch hand is resetting wrong
Click on my name (escapement), then click on TIPS AND TRICKS. Browse through all and you will find the link to all CASIO watch manuals. Rate me, please.
Jun 24, 2010 | Casio AMW330-7AV Wrist Watch for Men
The watch is self widing. ait just stopped working
Yes I do. Don't try to fix your watch.
My watch maker friends have told me that generally speaking, the reason most self wind mechanical watches stop is: (1) they need cleaning or (2) the screw that holds counter weight in the watch (that actually does the winding) comes unscrewed. He said most of the watches that have been worked on by the customer have lost the screw.
My advice remains have your watch looked at professionally.
Any other concerns my friend?
Jan 14, 2010 | Watches
Stopped working for no reason
There is always reason if the watch stops and the most common is flat battery. Change the battery in your watch and see if it starts working. If watch doesn't work after battery replacement, then there is mechanical or micro electrical fault and you will have to ask watchmaker to find out what's wrong and fix it.
Rate me, plz.
Jan 11, 2010 | Giorgio Armani Armani Leather Collection...
My watch constantly stops
check for automatic winding offcentre disc clutch mechanisum fault
Aug 24, 2009 | Seiko Watch SNXJ89K1
Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Aug 05, 2009 | Watches
The stop watch second and minute do not reset to 12 . Dallas
To reset the stop watch unscrew the stem and pull it out 1 click. Then press the buttom to the top of the stem and it will move the minute stop watch 1 minute continue to press to get it set to 12. Do the same with the bottom button to get the second hand stop watch to 12.
Sep 01, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
I just recieved a Fossil FS4249 chrono wrist watch. It has a tachometer with serated/knurled outside ring. The ring does not appear to turn. No mention of the use in the instruction booklet. Thanks, Jeff
On a chrono watch the the tachometer ring is fixed. The tachometer is used with the stop watch feature of the chrono. If you start the stop watch while travel a measured distance....say a mile...stop the stop watch at the end of the mile. The stop watch will indicate the amount os seconds...also the needle will point at the speed on the tacho. 45 seconds points to 80 mph.
Jul 25, 2008 | Fossil Watches
Tag Heuer Formula One Logo
73 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
