Question about Universal Remote Control Remote Control
How do I program my ge universal remote for my sanyo dwm 1000 m
Fenikstoneel
    New Friend:
    Problem Solver:
  • 6 Answers
The code for the remote control for sanyo dwm 1000 is "0681"
Posted on Jun 08, 2014
5 Related Answers
Anonymous
  • 121 Answers
SOURCE: need codes for rca tv using ge universal remote
Here Are Some codes 000, 003, 004, 005. 006, 007, 019, 096, 098, 099, 100, 101, 102, 103, 129, 179, 181, 188, 190, 203, 212, 233. For t.v.'s............Hope this is help full.. : )
Posted on May 07, 2009
Anonymous
  • 647 Answers
SOURCE: need the tv program codes for sylvania tv. for
Check the attached link it may help.
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Dec 03, 2009
Anonymous
SOURCE: I need to program ge universal remote jc024 for
I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
Posted on Mar 04, 2010
Anonymous
  • 109 Answers
SOURCE: i have lost the ge universal remote guide for the
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
Posted on Jun 13, 2010
Anonymous
  • 1340 Answers
SOURCE: I'm looking for a GE universal remote code to
Be right with you...looking up.I have found a site which does not require Adobe.I will list the link and you can look.If you still need help,feel free to let me know.The rest of this was written before I decided just send the link DUH lol.Good luck!Ahh bummer.I need more info about the TV please.Is it older style,HD,combo,and there is a category for other...lol.I also need to know if the remote was bought before or after Aug. 2002(probably new right,or did you just lose your signal or code or anything like that).
http://www.eliztech.com/remotes/ge-new-3digit-tv-codes.php
Posted on Aug 01, 2010
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
I'm trying to obtain the remote control code for a SANYO (model#AVM-1906). I'm trying to program it into a universal GE tv remote.
Hello
Univeral remote code for TVs with GE universal remote are:
0047, 0051, 0055, 0021, 0178, 0027, 0135, 0282, 0451
Three digit remote codes for Sanyo TV with GE universal remote control are:
049/097/110/004/265/012/108/180
OK.
Jul 08, 2011 | Sanyo AVM-1906 TV
I need the 3 digit setup code for a DWM-380 Sanyo DVD player to work with my universal remote. I tried 649 and 654 to no avail. Please Help!!!! John Baker
Try 147 - that is one for Sanyo DVD players.
Also try 003, 007, 010, 020, 053, 057, 082, 102, 187, 166, 187, 214, 266, 511.
Hope one of those works for you. Be aware though that depending on the remote you are using, it may or may not be programmed with the right code for this Sanyo DVD player.
Anyway I hope this helps. Thanks for using FixYa.
Jan 06, 2010 | Sanyo DWM-380 DVD Player
SANYO DWM-3000U combo dvd & vcr home theater system
I have a DWM 3000u that won't play some new DVDs. The movie is pixlated. Is there a firmware fix or do I need to buy a machine?
Lynda
Jan 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Sanyo DWM-2500 Subwoofer bass output
You cannot access the bass settings with the remote. The remote that comes with the DWM-2500 is Sanyo Part #RB-TS760MT
Oct 28, 2007 | Audio Players & Recorders
Codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Aug 13, 2007 | Sanyo DWM-390 DVD Player
Universal Remote Control Remote Control Logo
Top Universal Remote Control Televison & Video Experts
Kyocera HP Expert
Kyocera HP Expert
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
