Question about Magic Chef CTF2125 Top Freezer Refrigerator
How many cu. ft. is my GE GTS17BBMFRWW model refrigerator?
2 Related Answers
Nikhow
  • 436 Answers
SOURCE: What is the Cu Ft. of my Magic Chef Refrigerator
Hello there.
First you need to find your refrrigerator Model number.and put that in your question friend.
Go here and see for yourself how many Magic Chef models there are friend.
http://www.ebay.com/sch/i.html?_odkw=magic+chef&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR4.TRC1.A0.H0.Xmagic+chef+refrigerator&_nkw=magic+chef+refrigerator&_sacat=0
Posted on Sep 21, 2014
rpkrebs
  • 4 Answers
SOURCE: What is the Cu. Ft. of my Magic Chef Refrigerator Model # RB193AV? Previously put Model # in Select a specific product, 1st time on fixya
Hi Jim,
Because this is an older model and the CU feet many not reflect the size you can now fit with newer models (better insulation, etc.), I'd suggest going by the dimensions of the opening and allowing for the manufacturer's recommended clearances.
If you need further help, reach me via phone at https://www.6ya.com/expert/roland_e8cd37f59424d315
Posted on Sep 22, 2014
Testimonial: "Thank you. I understand the size would be bigger due to insulation. I have plenty of room, all new refrigs. have Cu Ft sizes and would like to buy one whose interior closely matches my existing."
Tfx25zr where is water filter
If your model has a filter The water filter cartridge is located in the
upper right-hand corner of the fresh food
compartment, right below the temperature
controls.
The filter cartridge should be replaced
every
six months or earlier if the flow of
water to the water dispenser or icemaker
decreases.
Download User Manuals HERE
Sea Breeze
Older Model
TFX25ZRY
Use and Care Manual for above model(s)
TFX25ZRBAA
Series 25.2 Cu. Ft. Side-By-Side Refrigerator with Dispenser
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBWW
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBBB
Quick Specs
Use and Care Manual
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Re: GE Model TFX24R Side-by-Side 23.6 Cu Ft Refrigerator The refrigerator door needs to be raised to correct closure, it is visibly low and stands open. However, I have not been able to figure out how...
the cam must have broke and this is why the door fell,the cams are made of plastic,part number WR2X4901 and it's around 15 dollars,there's a couple of shims that are there too but they should still be good,
May 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
WHAT IS THE CU FT OF THIS MODEL #
THE CU FT OF THIS UNIT IS / 25 CU FT / THE MODEL # SHOWES THIS. HOPE THIS HELPED MM. FEED BACK PLEASE.
Jul 22, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
How many cu ft is it?I have a tfx25zpbeww
The number in the model number is the cubic foot size. In this case, between 24.5 and 25.4, so it is called a 25 cubic foot model.
Jun 19, 2010 | GE Profile 21.6 cu. ft. Side-by-Side...
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Magic Chef CTF2125 Top Freezer Refrigerator Logo
108 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
