Question about Poulan "Poulan" Push Mower
Lawn mower running suggish - Poulan "Poulan" Push Mower
Joe Krupiak
    New Friend:
I had the same problem Poulan 550 It would start fine, start getting slower and slower then stall. Then it would not start for about 30-40
minutes than same thing. I put and new plug (set the gap with my handy gage) then took off the air filter and sprayed carb cleaner right into the carb. bowl. Put it all back and same thing.
But while it was starting to slow down I had a screw driver with me and with the engine running i loosened the screw on the air leaner and the engine started to rev faster. loosened a little more and rev faster again. FInally pulled the air filter and finished the whole lawn
on one tank of gas. I cant believe the air filter can cause such an
issue. And the air filter looked clean. Time to try a new one
Posted on May 18, 2015
J.D. Browning
  • Poulan Master
  • 2,760 Answers
Fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Posted on Feb 04, 2015
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
What happens to the lawn mower ir ite run with too much oil in it and why wont it run?
if you run a lawn mower with to much oil in it will smoke and foul the plug it will cause the engine not to run so chang the plug and start the engine with the oil at the right level
Aug 14, 2014 | Garden
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Scott bonnar lawn mower service manual model 520
i have a scott lawn mower,i have run it dry of fuel went to refuel.now it won't start.have cleaned the spark plug and poured fuel thru the carb any clues
May 17, 2010 | Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Poulan "Poulan" Push Mower Logo
209 people viewed this question
Top Poulan Garden Experts
dannydoesita
Marvin
Marvin
bryan st
Are you a Poulan Garden Expert? Answer questions, earn points and help others
