Walmarthttps://www.walmart.com > ... > Shop All Trash Cans
The touchless operation allows for improved cleanliness and hygiene, this trash can operates with hands-free motion sensing technology. Simply wave your hand ...
Rating: 4.6 · 1,428 reviews · US$29.94 · In stock
Hey, sorry for the confusion. Actually Ortho GroundClear can not be used in the Dial N Spray Hose End Sprayer because this sprayer will only dilute up to 8oz per gallon. This dilution rate is not enough for the product to be effective in keeping the area clear of vegetation. Hope this clears it up.
Hilary @ Ortho
If you are using Miracle-Gro Water Soluable All Purpose Plant Food in the Ortho Dial N Spray Hose End Sprayer, follow the directions below :
Set the dial to 4 oz
The sprayer can make up to 8 gallons of spray. Add the correct amount of product to the jar for number of gallons you wish to make. (Example - The dilution rate is 1 tablespoon per gallon, and you want to make 8 gallons, put 8 tablespoons of Miracle-Gro Plant Food in the jar.)
Multipy 4 by the number of gallons you are making and fill to that oz line (Example - If you are making 8 gallons, 4x8=32 so fill to the 32 oz mark with water).
Prior to spraying, mix product around in the jar until granules are dissloved.
Spray until the jar is empty.When it is empty, you have sprayed 8 gallons of product.
If you any questions or if you are using another product, please give us a call at 800-225-2883, and we will be happy to figure out a setting for you!
it sounds like you unscrewed the pump assembly. that chamber is actually part of the pump and sometimes they do separate. try to remove what you called the chamber. if that is part of the pump then it has to come out before you can put the pump assembly back together.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply.
Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist.
Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel.
In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding.
Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back.
Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons).
Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping.
NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
