Hi , my button element isn’t working in my frid. Prof gallery glass top oven . SERIAL number is cfes388wgc3. It is showing f1 error code . Could it be fuses ? Where are fuses located ? Thank you .uui
Mine is Frigidaire 30" electric stove model CFEF312FSB. One of the 8" element was broken with sparks when I put on a new switch. I plan to change a new switch, new socket and new element but there is no fuse as the traditional stove??? It seems there is no fuse anymore on new style of stove? Now there is no circuit when I test the socket, please help
Fef3543bfwe Bottom Unit Not Working Got New Unit In
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Hello meikle1961 - Do you have exact model number to the unit? Are you speaking about a gas or electric range? Reason I ask is because depending on the model number, there are various controls on some ranges. With this information I can assist you better in pinpointing you the part location.
