Question about Razor USA Razor Ground Force Drifter Go Kart
Troubleshoot razor kart controller - Razor USA Razor Ground Force Drifter Go Kart
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
Tip
Nice. Little tips like these go along way.
roll up some tin foil flatten it to the size of the battery you need,circumfrence not the actual size of battery,push it against the spring where you would normally put the bigger battery then push the little battery on on top so it fits tight in the slot for the battery,WALLA,you now have power.its the same principle with all batteries.
on Nov 09, 2010 | Razor 300001-SL Ground Force Go Kart
Tip
Gas Engine Conversion
Just converted our Razor Kart to a 49cc gas motor. Is twice as fast as the electric version but was very unstable with the stock wheels. I went with 4" slicks and is much better. Transplanted the drive train from a pocket bike with electric start and speedometer. Was a 2 day project and was well worth the time.
on Sep 12, 2009 | Razor 300001-SL Ground Force Go Kart
Repair
this unit may take several hours to charge correctly
May 21, 2013 | Razor USA Razor Ground Force Drifter Go...
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
Go kart doesnt run anymore wat could the problem be
Wire connection seems to be the problem with any electric dependent vehicles of that sort. They are usually cheap so the wireing is cheap as well. Check to see if there is any loose wires or even some cuts in the wire. Repair them if so. If not that...make sure anything that likes too dirty than what you think it should be...clean it off with a can of compressed air (don't put water on that sort of stuff). Keep checking around the kart and check for anything out of the ordinary and work from there.
Hope this helps ^_^
Jul 19, 2011 | Razor 300001-SL Ground Force Go Kart
Hello, I have 2 of these and they just stopped working, slight clicking sound but need help!
If your batteries are good and are putting out the proper voltage I would say your control mod has failed. Usually all the lights work but all you get is a faint clicking sound everytime you turn the throttle.
Oct 12, 2010 | Razor 300001-SL Ground Force Go Kart
Razor Ground Force Go Kart will not work.
replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Mar 05, 2009 | Razor 300001-SL Ground Force Go Kart
Razor USA Razor Ground Force Drifter Go Kart Logo
163 people viewed this question
Top Razor USA Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
