How do you open the case on a Mitsubushi XD50U to gain access to the fan cage ? i have something caught in my fan cage and it is making a loud clicking sound and it has not cleared out useing my vacume or compressed air .
sounds like a dead soldier is on the way. unless as simple as something caught in the fan casing. will probably need a new fan assembly. would be the best rought.a little expensive, but saves alot of headache troubleshooting
you need to remove your glove box assy.(beleave only 2 screws and pivot clips) make sure its not anything from glove box that has slipped behind. once box is out uf way you can access easier the blower motor assy. it actually attaches into blower box from bottom side. when looking at you will find three screw/bolts fastening motor to casing. remove those and then slowly lower motor and fan cage(attached to motor shaft) out from housing. sometimes it takes a little convincing to come out but not real tough. once out you most likely find the object causing noise in fan cage or resting up on lip area of housing unit. once found install in reverse order. let me know if this helps or if we need to dig a little deeper into! good luck!
joel
it is the fan or the blade hitting something when you open the door it shuts the fan off and on when closed you need to gain access to the fan and see if it is the motor of the blade before you lose any food
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
The side panel of the case should be removable to gain access to the screws. I have also seen versions that the card cage itself is on a hinge, and swings out of the case (with the removal of a few screws) that then gives access to the drive screws.
