Philips 220CW8FB 22" LCD Monitor Logo
Question about Philips 220CW8FB 22" LCD Monitor
Philips 227 el smartimage problem - Philips 220CW8FB 22" LCD Monitor
1 Related Answer
core
  • 7 Answers
SOURCE: smartimage problem on screen
Just hold the smart image button (last on left side of display)
I had same problem a second ago, so it worked for me.
Posted on Jun 17, 2011
Hello, I have a screen Philips 19IEL problem is a vertical line sanning left and right; at the bottom of the image is there mentioned Left: SmartImage On and SmartImage OFF.Pos can I stop this?
from a simple search of their FAQ page....
Back to FAQ
Question
Always appear text "SmartImage On/Off" mode(a vertical line move) on screen.
Answer
Please press the SmartImage key for over 8 sec to exit /or ON the demo mode.
Come togliere dallo schermo smartimage on/off?
Ho un monitor Philips I90sw e vorrei eliminale smartimage on-of.
Come faccio?.Grazie
My Phillips 191 EL model has a vertical line scanning back and forth. On the bottom it says smartimage on / off on both sides. how to fix it?
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
9helpful
How to remove the smartimage on my screen
i suppose you mean philips's smartimage
just press the menu button.
if you can't, probably you will need to return it or repair.
6helpful
2answers
My philips 191EL LED monitor was not functioning the menu buttons but have a display and in use while plug on, however, at below portion of the screen appears the word SmartImage on and SmartImage off. Is...
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
67helpful
4answers
How to stop SmartImage from 'Scanning' My screen?
Push the first button (begining from de bottom) five seconds and the option smartimage set to off.
46helpful
2answers
No buttons work on monitor and Smartimage on/off appears on screen with a line that floats across the screen.
734helpful
11answers
Smartimage problem on screen
Top Philips Computers & Internet Experts
Marvin
Marvin
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
