SOURCE: Fatal alert [Memory Mgr,C,Line:3751, Free handle
I fixed mine this evening by doing a hard reset. First I removed the card just to make sure I didn't harm the data on it. Everything else is lost in the memory of the handheld by doing this but at least you still have a gizmo that works! Others have suggested to do stuff and then do a HotSync -- lovely, but the HotSync was also seized shut!
To do a hard reset:
without a sharp tip) to gently press and release the reset button inside the hole
on the back of your handheld.
SOURCE: Palm Tungsten E2 error
Hold the middle button UP while tapping the reset button on the back. This should get it restarted. You probably need to delete some stuff taking up memory.
SOURCE: when i try to sync i get a Fatal Alert
To get rid of the Fatal Alert, perform the Hard Reset on the device.
Note:
A hard reset will erase everything on your device. All your data will be removed, and formats, preferences and other settings are restored to their factory default settings.
Follow the steps below to perform a hard reset on your device.
