Question about Moen & Replacement Cartridge
I have a new 12801 - how do I replace it
I have a new 12801 - how do I remove old one to replace it
Posted by K Hutchinson on
  • 36069 Jun 30, 2014
    Hi K Hutchinson, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
3 Related Answers
jasmic11
  • 9 Answers
SOURCE: need to replace moen cartridge
The Moen 1222 is the cartridge you want. The 1222 is the OEM number, and the cartridge carries a lifetime warranty. If you call moen at 1-800-buy-moen, they will likely send you a replacement cartridge free of charge. Some wholesale plumbing suppliers will also do it if you act like you know what you are talking about, and they don't have an aversion to "retail" customers.
Posted on May 05, 2011
lkjbwetrgw
Roger
Sure there is. Use this tool to check (find cheapest dealer with high quality product) http://tinyurl.com/cartridge12801wholesale Best of luck
Posted on Oct 31, 2014
jhbwertgwer
Abraham
yes, there is... go to amazon here Amazon com moen cartridge 12801 and take a look. enjoy
Posted on Nov 22, 2014
Do any plumbing stores carry moen 12801 replacement cartridges
I am not familiar with that cartridge, but most hardware stores and plumbing supply houses should have Moen parts. #'s 1224, 1225, 1200 and 1222 are the cartridges I'm familiar with.Bring the part with you.
May 19, 2014 | Moen & Replacement Cartridge
Replacement cartridge?
Hi, Try the #12001 It may solve your problem check to see if diameter is the same size.
Sep 28, 2013 | Moen Plumbing
I lost the userguide of my quigg ultrasonic cleaner, type SR 630.09. And i want to clean my watch and jewelry. Can anybody help me use this machine.
This Manual will give you the Information to get it working correctly again... Good Luck
http://www.manualswall.com/results.php?lang=en&search=MICRO+ONDE+QUIGG+MD+12801+USERS+GUIDE#.UWMt8VeRfAI
Apr 08, 2013 | Watches
Need power cord
go to www.repairclinic.com or call
(305) 685-8500 Marcone appliance
12801 NW 7th Ave, North Miami, FL 33168
God bless you
Jul 19, 2012 | GE 169216
Need a moen 12801 cartridge
Sure, take a look on amazon: Amazon com moen 12801 cartridge. I hope this was helpful. Cheers
Jun 07, 2011 | Moen & Replacement Cartridge
How do i replace ps 652226 ice funnel ge ziss480drbs
carefully removed the trim from around the dispenser area by gently prying the trim off careful not to brake it. then freed the catches in the top of the electronic card. I leaned the card forward and disconnected the electrical connections, then removed the card. I removed the four screws holding the shield to the door and removed the shield. Then I removed the funnel from the shield and removed the spring from the old funnel and placed it on the new one. I removed the light and socket from the old shield and installed the in the new one, then installed the new funnel on the new shield, used the four screws to install the assembly on the door and replaced the trim piece. Here's a DIAGRAM to help.
Mar 05, 2011 | Refrigerators
Moen & Replacement Cartridge  Logo
142 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
