ToshibaApr 9, 2013 - Blu-Ray Player does not respond to some operating commands during playback; Random lock up of Blu-ray player occurring after the unit is turned off ...Check to make sure that the unit is plugged in securely to the power source (outlet,... Toshiba BD-Live enabled players offer the ability to allow different ...
PDF]BDP - S185 / BX18 - Sonyhttps://docs.sony.com/release/BDPS185_BX18.pdfSony Corporationray Disc/DVD player is harmful to eyes, do not attempt to disassemble ... Install thisunit so that the AC power cord can be ... Connect the equipment into an outlet on a circuit ... type plug has two blades and a third grounding ... Do not turn up the volume while listening to a ... protection systems used in both Blu-ray Disc™ and.[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warrantyhttps://docs.sony.com/.../BDPS1200_BX120_S3200_B...Sony CorporationDVD Player. Operating ... in this Blu-ray Disc/DVD player is harmful to eyes, do not ...Install this unit so that the AC adaptor can be unplugged ... Connect the equipment into an outlet on a ... If the provided plug does not fit into your outlet .... Do not turn upthe volume while listening to a .... BD-Live™, BONUSVIEW™, and the.[PDF]Smart 3D Blu-ray Disc™ / DVD Player with Built-in .
This probably means that your DVD player has a dirty lens or a tracking problem or both. If the DVD player has a tray, you can try putting an optical disc lens cleaner into the unit. (Slot-loading DVD units may not properly accept or eject the disc. So don't try a cleaning disc in that type of unit.)
Since most DVD players are cheap, it's usually better to replace the unit if the tracking is bad. Similarly, if a lens cleaner does not work, replace the unit. If the player is under warranty, contact the manufacturer.
Hello The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Tries to play more than one DVD disc.Tries to play many DVD disc should be original DVD disc ok no DVD+R copying disc ok.If ur are still getting signal just saying loading signal awhile than say no disc show up, and u did playing it with many dvd original disc.Than the DVD player laser eye reader could be ditry.Tries websites like Amazon.com,Ebay.com to buy a DVD disc set that said like DVD players lasers eyes cleaners.Used it as directions said,if u still getting the same result mean ur DVD player laser eye reader it is dead,not worth repairing the DVD player if the DVD player laser eye reader it it dead,because the laser eye reader it is 90% important to the DVD player unit and the cost of it by replacing it will cost the same as a new DVD player unit.
2. Switch off the DVD player and unplug the power cord.
3. Wait 30 seconds, then reconnect the power cord.
4. Turn on the DVD player with the supplied Samsung remote and wait for
player to finish loading and display 'no disc' or the Samsung logo
before you do anything else.
5. Press Enter on remote. (There will be no on-screen response to you doing this.)
6. Press the following numbers in sequence using the supplied Samsung remote unit's keypad -
8 4 2 6 9
(Again, there will be no on-screen response to this action.)
7. Press Enter on the remote. The DVD Player will automatically shut off.
8. Now, turn the DVD player on.
9. When it is on and showing the "no disc" or Samsung logo, turn it off again.
10. Repeat this action by turning the DVD player on, then off again.
Sounds very much like you have a either a dirty laser, or a laser unit failure. Put a cleaning disc through the machine, and see if it improves. If not, then you need to either have a new laser fitted, or a new machine.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys: SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
try to manualy clean laser lens (the little glass looking bubble )with canned air dont touch then wipe the rubber area where disc sits on when a disc is loaded off with windex applied to a microfiber towel then try to use.
