Question about Mercedes-Benz Vehicle Parts & Accessories
99 280 c cd disc changer says changer is empty, although all 6 cd's are present.
Posted by Allenberg Galleries on
Fran Roles
    Scholar:
    New Friend:
  • 88 Answers
Try ejecting all discs then remove the fuse that powers the device for 30 seconds. If this does not work try blowing air into slot of player to remove dust. Dust blocks the disc sensing diodes (you may have to remove the unit if it is real dusty). If this still doesn't work there is a problem with the photo diode.
Posted on Jun 13, 2014
When i change from radio or single disc to the 6 disc changer there is an error it won't read any discs.... It wont even change discs it won't do anything really...
I suspect that your 6 cd changer is having the fault. The error indicates always a system malfunctioning. From our point of view we can probe into for a solution by the following guidelines.
first of all open the 6 Cd changer from the top. look within to find that the changer is jammed inside. If so slowly tapp while you switch on the power. if the jamm clears and the changer ejects, then open out all the cd's present in the changer for any damage due to heat. If this did not solve, clowing chek for foreign particles/dust that has blocked the loading drive.from completing the cycle so as to reset the mode. normally all errors show because of the processor not receiving the complete cycle signals. hence check for all the moving parts, the drives and the loading mechanism. check also for any linkage damge, any leadd specially flexible line wiring to the motors for an open circuit. Slowly turn the motor drive to intiate to confirm if the motor has failed. Altogether use a multimeter and check in all the sections described.
I hope this helps. Good day.
Jun 28, 2010 | Car Audio & Video
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
6 disc cd changer
have you cleaned the lens on the cd changer??????
Oct 07, 2008 | Alpine CHM-S620 6-Disc CD Changer
Won't Play CDs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
www.carradiospares.co.uk
Oct 08, 2007 | Alpine CHM-S620 6-Disc CD Changer
Changer won't acknowledge discs
regards
Mark
Jul 30, 2007 | Alpine CHM-S620 6-Disc CD Changer
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
