Homedics SC-405 Digital Bath Scale Logo
h
hilda wollschlaeger Posted on Jun 07, 2014
Does not regester wt. put new batteries in ??
The numbers stay like 13: 2 I DONT WEIGH THAT I PUT IN NEW BATTERIES????
fivefootgirl
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 06, 2015
fivefootgirl
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
986
Points
7
It's probably reading you your weight in "stones"
on the top, upper left corner of the back there's this little button you can push to toggle between pounds, kilograms and stones
Kingsley Pro
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 07, 2014
Kingsley Pro
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1505
Points
12
Whenever i put the batteries on charge... it shows a troubleshoot and then after five mints the red light turns off and the charging stops... i dont know that the problem is
I think either the batters or the charge is bad. Try charging new batteries first. If the error goes away, then the batteries were the issue. If the error stays, then please update your charge next.
Thank you.
Oct 24, 2022 • Cell Phones
Hello: my digital food scale (taylor digital biggest loser brand) goes on but it does not weigh anything. its stays at zero. i've had it a year but only used it once or twice, so its almost never been...
Hello, Maclay55 -
I hope you checked the owner's manual first, the troubleshooting / problem solving section.
It wouldn't hurt to put new batteries in the scale (2 AAA batteries).
Note: From the instructions for the scales:
6. Do not store scale where you store cleaning chemicals. The vapors from some household products may affect the electronic components of your scale. Do not store scale on its side.
7. This scale is an extremely sensitive weighing device. In order to prevent run down of the battery, do not store anything on the scale.
8. Do not dispose of batteries in fire. Batteries may explode or leak. Do not mix old and new batteries. Do not mix Alkaline, carbon-zinc (standard) or Nickel-Cadmium (rechargeable) batteries. Remove the batteries if the scale will not be used for a long period of time.
Source:
1037BL The Biggest Loser by Taylor Stainless Steel Platform Scale Instruction Manual, pages 4-5
http://taylor-enviro.com/media/IBs/1037BL_ib.pdf
If installing fresh batteries does not work, then I suggest you call the Taylor USA Consumer Help & Support department. This is the link to the web page with the US and Canadian telephone numbers:
http://taylor-enviro.com/taylor-support/
Best wishes.
Replaced coils, will idle,but wont stay running under load, also have to keep charging battery
because the bike is so new i wouldnt suspect the stator i would invest in a battery, a good battery is crucial for bikes. once you get a good battery in it check the voltage at the terminals when the bike is running(you should see around 13 to 14 volts). you can have the battery load tested at a batteries plus or an auto part store so you dont waste your money, but once you kill a bike battery there pretty much junk. the stators in motorcycles barely put out enough power to run the bike and pretty much trickle charge the battery. they rely on the battery to pick up the slack. get a battery from walmart there cheap and ive had one in my bike for two years and its fine, stay away from the over priced ones they dont do anything but slim down your wallet.
7helpful
2answers
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
2helpful
My jenson mp3 model smp-2gbl wont stay on
i have a jensen model# smp 2 GBL it wont play it comes on for a second then turns off. I took out the music put in new music then it played for 5 minutes then turned off and does the same thing again. I put in alot of new batteries that dont work either can you help me
I have a schwinn missle fs and it has new batteries. i put the charger on it to charge and the charger light says it's charged but it's not. What could be the problem?
I've never worked on a Schwinn battery-powered scooter, but I'll weigh in--I'd check that the batteries are properly connected to the scooter. The charger may be connecting to the batteries, which are charged, but if the batteries aren't connecting to the motor, you're not going to go anywhere.
The only other thing I can think of to check is for blown fuses. Good luck.
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Even New Batteries Wont Work. Camera Shuts Down Immediately
Clean front and back + - terminals in camera careful with fine emery paper. Also, MAKE sure batteries are not loose if they are they will not make the connection. Fine jeweler screwdriver will pick them out enough.VERY CAREFUL.I truly think this is it.regards Billy
Top Homedics Health & Beauty Experts
jws1013
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
