Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
How to fix yellow ink showing on page after printing SX425W
HOW TO REMOVE YELLOW LINE FROM PRINTED PAGE
Zone8
    Scholar:
  • 60 Answers
Your description of the problem is so vague it would almost be impossible to provide any attempt to resolve this for you. For example - a blob of yellow, patches, lines, missing lines, perhaps a band somewhere across the page or down the page? In any event if it is, say, a thin line running across the page or down the page then that could well be a symptom of a blocked nozzle on the printhead. How often do you use the printer and do you carry out nozzle checks? Is the printer generally in very dry room conditions? So, as an attempt to resolve this for you with only the very limited description you have given, try the following. Set a page to Print to bring the Printer Dialogue Box into view. Click on Preferences and then on the Advanced Tabbed page. On that page, click on Nozzle Check and with a standard sheet of paper in the printer, click to do that check. Examine the output - there will be an example of what it SHOULD look like onscreen - meaning a specific pattern without any breaks in the lines. Even a tiny break indicated some blocking of the nozzle jets. Then use the CLEAN facility offered to clean the nozzles and repeat the nozzle check. That is the most likely cause of your problem. Come back if you still have the problem.
Posted on Jun 07, 2014
5 Related Answers
gwbm
Gerry Millward
  • 353 Answers
SOURCE: Epson stylus c66 printer will only print in yellow.
Hi Kirstymaher.
Are you confident the new cartridges are full and in-date? Did you remove the yellow tape from all the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred? Have you carried out more than one head cleaning cycle? If not, do another, then do a nozzle check print. Any sign of ink other than yellow? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done several head cleans with no result, and you're sure you have good ink cartridges properly installed, then You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Posted on Mar 15, 2009
gwbm
Gerry Millward
  • 353 Answers
SOURCE: only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
Posted on May 05, 2009
Anonymous
  • 4 Answers
SOURCE: i get horizontal yellow lines all the way down the
Not sure if the situation we're in is the same. I have a similar problem, but instead of yellow lines, it is pink lines. printer is Epson RX510. The lines are more prominent if the print quality mode used is best and if the document to be printed requires the affected color. Upon consultation with the printer technician, I was adviced that it is the print head which has a problem, and changing it is costly and the repair duration even depends on parts availability. With that, I just decided to use the printer just as is. Hope this info helps.
Posted on Jun 16, 2009
adnanbhatti
Adnan Bhatti
  • 1188 Answers
SOURCE: Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Posted on Aug 07, 2009
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
SOURCE: yellow line problems
may be the colour catridge is not working properly just remove it and clean it and install it if the problem is continue then replace the colour catridge and install new one.
Posted on Jan 21, 2010
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
Epson troubleshooting
What you have I highly suspect is a highly clogged print head. Even if you continue to clean your print head you will use ink to do it, so you will be spending a lot of ink and trust me it wont fix the problem. I have two epsons 1400 and had the same problem and used cleaning solutions but at the end it helped but did not fix the problem.
So at the I decided to use a cleaning solution that comes in cartridges specific for your printer. Its name is UNBLOCK UNCLOG CARTRIDGES, Its seller in E-bay is Sy1507. It worked. but for example it took me around three days. I printed a job and let it sit for a couple of hours until the page printed all white. After the page prints all white then you change the cartridges with ink and do a test print and if prints right, do a print job, You will be amazed at the results. Good Luck.
Jul 25, 2014 | Epson Stylus Sx445w Inkjet Print Scan 5760...
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
I have a bizhub C450 and i am getting a yellow line at the top of my printed page and also 2 pink/red dots in the middle of the page. How can i stop this?
The yellow and magenta image units may be the problem. Yellow may have worn out on one end causing the yellow line. If the pink dots show up on every page but move around from page to page, there may be damage to the magenta image unit. You can remove the image units from the machine and look at the drums (long green cylinders), this should be shiny and clean. If not, you may need to replace.
Apr 28, 2010 | Konica Minolta bizhub C450P Laser Printer
My printed page has yellow streaks on it. I have cleaned the roller mat, it just gets junked up again
I had the same problem. I was using a refurbished yellow cartridge which have never given me problems before. This particular cartridge ran fine until it was almost empty then I had yellow streaks showing up all over my pages and the roller in the printer was covered with yellow ink. I cleaned it a few times but that made no difference until I replaced the ink cartridge. Now it is printing clean again.
Jun 24, 2009 | HP Office Equipment & Supplies
Yellow ink is not printing properly
i think your cartige yellow ink had finished or dried up what u can do is refill yellow ink or dip cartige into hot water.... and clean it nicely it works
May 20, 2009 | Canon Pixma iP4500 InkJet Printer
Black ink is bleeding into the yellow
you may try to clean up the sensor, it behind the cross bar is a clear plastic strip clean whit alcohol, good luck!
Dec 13, 2008 | Epson CX8400 All-In-One InkJet Printer
Lines across printed page
try to locate the print head of the unit. you will see a mirror there. clean the mirror maybe it has some foreign object.
Jul 04, 2008 | HP Color LaserJet 2600n Printer
Yellow Prints in the other colors
Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
Jun 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
